Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 04-08-2007, 12:42 AM
k-townracer k-townracer is offline
Send a message via Yahoo to k-townracer
After market engine question
I have a 1998 neon sport. would it be possible to put a 3.0 dohc or possibly a supra engine rather then the stock 2.0 dohc. any advise and or info would be great. thank you for any advise you can give me.
Old 04-10-2007, 07:41 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: After market engine question
If you have enough money, time and know-how...then anything is possible.
The most common swap for the neon is the 2.4 from 98-01 Chrysler engines. You can also swap in the SRT-4 engine, but that takes quite a bit of rewiring.
2003 Dodge SRT-4
Old 04-11-2007, 05:37 PM
how much rewiring would be needed to put in the SRT-4? and would it still be compatible with the existing 5 speed tranny?
Old 04-11-2007, 08:29 PM
There is alot of rewiring for the SRT-4 swap and it is compatible with the 1st gen tanny.
2003 Dodge SRT-4
Old 04-15-2007, 05:24 PM
can i put a tubo on the SRT-4 as is, or do i have to put other things on it too?
Old 04-15-2007, 08:16 PM
The SRT-4 has a turbo on it already.
2003 Dodge SRT-4
Old 04-24-2007, 05:08 PM
where could i find an SRT-4 engine, and how much would one cost?
Old 04-24-2007, 08:17 PM
Try ebay or www.car-part.com and will run you anywhere from $1000-$3000.
2003 Dodge SRT-4
Old 05-01-2007, 07:21 PM
I try'd looking for the SRT-4 engine on www.car-parts.com, and could not find it. what do i need to go to on the site to find the SRT-4 engine?
Old 05-02-2007, 07:28 AM
Put 2003 for the year, engine, and then what city or state you are in and click search. It will then prompt you for which engine you want and then click on the "w/turbo (VIN "S")" and click search again.
2003 Dodge SRT-4
Old 05-03-2007, 08:30 PM
SimonTempler SimonTempler is offline
Don't forget the stratus engine also and go all motor.You would need a Mopar Proformacne ECU,MegaSquirt or a A/FX and a harness from a DOHC neon
Old 05-03-2007, 08:32 PM
MS would be overkill for a N/A engine.
2003 Dodge SRT-4
Old 05-03-2007, 08:38 PM
No doubt just throwing out some options and what not oh check crigslist for srt 4 I've seen those two engines on e-bay the last one went for 800 or less and try neon.org
