Go Back   Automotive Forums Car Chat > Saturn > LS/LW
Old 04-07-2007, 09:57 PM
mjmillsut mjmillsut is offline
power Loss
I have a 2003 Saturn L200 and we have had some power loss problems. When the car is idling the tack bounces around and the car shakes. Almost like the car is not getting enough gas. Also with acceleration we have power loss. The car will not have full power, and it will shake. Sometimes it almost sounds like some small backfires. The light that looks like an engine is on, but when we have power problems the light blinks. The book said this is a sign of miss fire.
I have changed the fuel filter, put gas antifreeze and water remover in, drained the gas tank if we got bad gas, tried to find all vacuum hoses and check them, and took all spark plugs out and cleaned them. they did not look bad, but had some black suff (carbon deposit) on them, And none of these help.
Had anyone else had this kind of problem?
Old 04-11-2007, 06:42 AM
HAWG HAWG is offline
Re: power Loss
try checking the ignition module and coil.
Old 08-06-2007, 05:58 AM
zatrony zatrony is offline
Re: power Loss
you probably dont want to be driving in that condition...it sounds like one of your cylinders isnt firing properly. youre barking up the right tree with the plugs, etc, and the coil is good advice. i would also put in a new set of plug wires. so many people forget that wires are regular (~75,000 mi) maintenance, but so critical to proper performance. also, while youre at Auto Zone getting the wires, ask them to hook up their diagnostic tester to read your engine code. they do this free and will tell you why your engine light is coming on. hope this helps
