Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-07-2007, 07:49 PM
Duncan1 Duncan1 is offline
Question Engine misses
1994 Caprice Wagon, LT1.
During light to moderate acceleration car runs absolutely perfectly. When I accelerate more than moderately the car takes off like it should but then the engine cuts out repeatedly for a second or so. Those are violent jolts and very disturbing. Anyone have a clue? I just replaced fuel and air filters.
Old 04-07-2007, 09:56 PM
Blue Bowtie's Avatar
Registered Offender
Re: Engine misses
Weak spark energy can cause misfire under heavier load. That can be due to worn plugs, failing wires, a failing coil, distributor, or connection problems.
Scanning the PCM while driving can also reveal weak spark or lean fuel mixture.
Old 04-13-2007, 08:39 PM
hondahappy86 hondahappy86 is offline
Re: Engine misses
im guessing you have a worn out opti.......mine did the same thing....plus check to make shure your waterpump gaskets arent leaking too.....
Old 04-17-2007, 11:39 AM
Re: Engine misses
What's an opti and what would the water pump have to do with it?? Thanks for your reply!!
Old 04-17-2007, 11:47 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Engine misses
The "Opti", or Optispark distributor is what fires the plugs. On the LT1/L99, this is at the front of the engine and is driven from the cam. It, in turn, drives the water pump.
If the water pump leaks, this can spell doom for the Optispark unit.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
