Old 04-07-2007, 07:39 PM
Becky1 Becky1 is offline
91 Lumina won't start
I own a 1991 Chevy Lumina 3.1 and lately when I would go up hills it would hesitate some but other than the hills it would drive fine. It would also idle high when stopped at lights. Yesterday I went to start the car and it would not start it would crank but not start. I put the code detector on the car and it said it was the EGR Valve so I replaced it, not the problem the car still will not start. All help would be appreciated.
Old 04-07-2007, 11:34 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 91 Lumina won't start
I think you have two problems running concurrently...the eGR probably fixed 1 and 2, but the no start has nothing to do with that...
Try shooting starting fluid in the intake and see if it fires on that...if so, you have a fuel delivery problem...if not, may be an ignition module, crank sensor, etc...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 04-08-2007, 12:51 PM
I used the starting fluid in the air intake and the vehicle started. Once I stopped spraying the starting fluid the vehicle stopped running. Not sure what to do next, any help would be appreciated.
Old 04-08-2007, 01:04 PM
Scrapper Scrapper is offline
AF Premium User
check the coil pack i think on my sons car there were 3 in the pack...so if no spark no run..and if sparks fuel pump or module,cps..good luck..........
Old 04-08-2007, 01:51 PM
I have checked the fuel pump and it is working. I also checked to see if there was spark and there was. I need to know where the CPS is located at. Thanks
Old 04-08-2007, 01:57 PM
CPS is fine if it started...your fuel pump or FP relay is bad...check fuel pressure at the rail, if below spec, the injectors won't open....
...empty gun rack.
Old 04-08-2007, 02:00 PM
I guess you've tried giving it some gas while cranking?
If an EGR is stuck open, it'll take half throttle or so to get it to start...sorry, I forgot that possibility...but since you changed it, I can't see why that would happen...
...empty gun rack.
Old 04-08-2007, 02:39 PM
Thanks for your help. Changing the EGR fixed one of the problems but for the car not starting I check the 10 amp injector fuse and it was blown and replacing it fixed the problem as the car started right up. Again thanks for all your help.
Old 04-08-2007, 04:07 PM
i just started the car again and the fuse blew again. could there be a short in the fuse box or the fuel injectors. your help is appreciated thank you.
Old 04-09-2007, 06:59 AM
AF Premium User
cps is right behind your harmontic balancer..but if you don't know what your doing you might take it to a shop.you need a special tool to set sensor. to set it right..this can cause you a big bunch of trouble if you don't do it right. you might want to get a hanes manual from autozone or avanced.....
good luck...
Old 04-09-2007, 10:00 AM
After figuring out that a 10 amp inj fuse had blown we changed it and the car ran for a short time and than the fuse blew again. Any ideas of what could be causing this? All help is appreciated. Thanks
Old 04-09-2007, 04:29 PM
Make sure the CPS harness isn't rubbing the harmonic balancer and shorting out...I think the CPS has it's own fuse but maybe not on your year...
...empty gun rack.
Old 04-10-2007, 07:45 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Jeff, check the harness that runs from the CKPS, across the back of the engine, under the harmonic balancer, and over to the ICM. If it has gotten into any mnoving parts (pass cv axle, harmonic balancer, serp belt) or touched an exhaust manifold and melted, it could be shorted causing that fuse to blow. Also check the big main harness connector for the fule injector rail (near the alternator) for signs of corrosion, wear.
Scrapper, the CKPS needs no setting and on this year car is not behind the balancer, but in the back of the block just above the oil pan rail slightly toward the passenger side. The sensor is designed to only go in one way. There is no air gap to be set like the older 3800's or any type of adjustment. The 3.1 didn't use the 2 CKPS's (with the 2nd behind the balancer) until 94.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-11-2007, 09:43 AM
AF Premium User
thanks for clearing that up for me.like i said my son had one. the dumbust thing i seen on that car was the battery was locaited under the coolant jug.
my fault not looking at the year....
thanks again.....
scrapper..
Old 04-11-2007, 04:29 PM
richtazz's Avatar
no problem scrapper, I know how easy it is to get confused from year to year changes. I just didn't want anyone getting mis-led looking for something that wasn't there on their particular vehicle.
