Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 04-07-2007, 06:49 PM
chevy 454 ls6 chevy 454 ls6 is offline
help! adjusting valves on a 1970 454 ls6
can somone help me with this proceedure? any links or input is appreciated
A pic for your click
http://x013.uploaderx.net/x/538.jpg
http://x013.uploaderx.net/x/549.jpg
Old 04-07-2007, 06:50 PM
Old 04-08-2007, 04:59 PM
Blue Bowtie's Avatar
Registered Offender
Re: help! adjusting valves on a 1970 454 ls6
Rotate the engine to TDC of the compression/firing stroke on the #1 cylinder. Mark the balancer in quadrants with chalk or tape or whatever else you like, then adjust the clearance to specs on both valves for the #1 cylinder. Turn the crank 90º, and do the same for #8. Turn the crank another 90º and do #4. Follow that procedure through the firing order and you'll be done.
Old 04-17-2007, 06:36 PM
highlandlake highlandlake is offline
Bowtie,
That was the easiest DIY tip I've seen in a reply in awhile. Makes sense, Will this work for all V8's?
Tom
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 04-18-2007, 01:36 AM
Registered Offender
Unless there is some really odd valve timing, that should work for setting both solid lifter lash, or for pre-lashing hydraulic lifters. Of course, you'll need to spin the push rods or use some other means to determine the zero lash point with hydraulics, but the concept is the same.
