Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 04-07-2007, 06:35 PM   #1
Evilmonkey1177
Evilmonkey1177's Avatar
Send a message via AIM to Evilmonkey1177
Limp Mode? I've searched
My car seems slower than usual for no reason. No codes. Haven't been driving with shift plus on. I keep very good care of my car. But it just seems slower on the past couple of tanks of gas. If used fuel system cleaner and such with no luck. Only other issue is when I got my trans fluid changed at AAMCO last summer they checked for codes and said they couldn't get a signal from my ECU. Any thought or comments on what could be causing all this?
Evilmonkey1177 is offline   Reply With Quote
Old 04-07-2007, 07:01 PM   #2
muff34
Re: Limp Mode? I've searched
plugged fuel filter, plugged catalyitc converter , air filter ? how many miles? does it start ok ? does it idle ok. when was last tuneup?
Life Is A Highway ,Enjoy The Ride
muff34 is offline   Reply With Quote
Old 04-07-2007, 07:11 PM   #3
Evilmonkey1177
53,956...Starts fine.. stock cat... idle is low 700ish but pretty steady... idk about fuel filter which was my first guess. My car just has no go. Shifts into every gear and all but just doesn't pick up. And low MPG too...about 25 on the highway..well lower than ususal i should say.
Old 04-07-2007, 08:03 PM   #4
DeadBlade89
DeadBlade89's Avatar
Send a message via AIM to DeadBlade89
ya, change the fuel filter and go from there.
2000 Pontiac Sunfire SE
Originally Posted by freakray
You're right, I actually own a '94 Civic, I just put Subaru badges on it and make the turbo noises as I drive down the road to fool other people.
DeadBlade89 is offline   Reply With Quote
