Old 04-07-2007, 05:30 PM
Hotshot8792 Hotshot8792 is offline
she wants it bad
Like the title says, she wants to be back on the road really bad, and progress is finally starting to be made. As some of ya'll know, i've already had this, and I finally cleaned them up today:
DR Stage 3 heads
and look what I finally picked up yesterday morning:
This should hold any power that I could possibly throw at it. Arias Forged Pistons 8.5:1 CR and 3.05 L displacement, Pauter Forged Rods (they are a little bit lighter than the stock rods), 2nd gen crankshaft, all in my old 2-bolt block, because I didn't want the extra oil squirters. It was machined, balanced, and assembled by a professional shop who builds race engines for drag pro cars on a daily basis, as well as some street engines as well. I can't wait to get it all assembled and back into the engine bay.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 04-07-2007, 05:58 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: she wants it bad
Nice!!!
Old 04-07-2007, 07:29 PM
Igovert500's Avatar
blue + red light magnet
Sweet. Really looking forward to seeing what you are going to be doing this year.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-07-2007, 07:58 PM
AutostradaVR4 AutostradaVR4 is offline
mmm...sexy...
yea, cant wait to see what kinda times you put down.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 04-07-2007, 09:03 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i noticed you have 91-92 heads with the adjustable CAS on the passenger side of the head. any reason for that? or do you intend to convert it to the later unadjustable CAS on the rear exhaust cam gear?
i've noticed a lot of ppl on 3Si have said how they don't like the extra oil squirters on the 4-bolt blocks...why is this? how could extra lubrication hurt? what parts of the motor (internals, obviously, but which exactly) do the oil squirters lubricate?
are you sticking with the 18Ts, GM MAF/MAF-T, and EBC? any changes to the setup? what injectors were you/will you be running?
give us the whole kitten caboodle! don't hold out like 3SX and be all secretive with your tricks .
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-07-2007, 09:11 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Linebckr why wouldnt you want adjustable timing? Alot of 2g guys convert to that style CAS for its adjustablity. Plus it can go on any 91-99 engine whereas the 93-99 style wont work on a 91-92 head.
Old 04-07-2007, 09:24 PM
Originally Posted by BlinkRA182
mmm...sexy...
I doubt that I will have any times this year. It will probably take me until somepoint during the summer to finish it, and then i'll be spending a few months breaking in the motor and tuning it. Then the track is closed during the colder months.
Old 04-07-2007, 09:42 PM
I have the 91 heads because I bought them used with about 2,000 miles (as well as the pistons and rods) from a 3SI member who was parting out his car. He had a good price for them so I jumped on them quick. I bought a 92 TT ECU for better fuel maps. I am using the N/A harness since the 94 fed spec n/a harness lines up with the pins on the 1st gen TT ECU. The only change i had to make was adding in a 2nd O2 sensor, in which the dealership gave me a couple of ECU pins so I could add into the connector. So I added in the 2nd O2 sensor.
As far as the extra oil squirters go, they don't lubricate anything. They are used to help keep the the stock pistons cool which really aren't needed with forged pistons. They also drop the oil pressure going through the rest of the block which is suggested to be a reason for spun bearing problems.
I won't be secretive. I will be running E16G's on JPDC adapter plates and O2 dumps (for now). I may upgrade to manifolds in the future, but I am satisfied with having the adapter plates. My other mods will pretty much be the same as before. I will be removing the SFS LSD insert and get a real LSD since the inserts have backfired on multiple applications.
I have also done the automatic climate control conversion, LED conversion, ran real speaker wires to all of my speakers as well as replacing the rear 6x9s. I had a huge mess of wires on the inside and had to rewire a lot of crap. I put real gauges in the stock center location, and everything (turbo timer, EBC, e-mainage) is hiding. I want to seem like I have a stock interior. I'm real close to putting the dash back in the car and then I will get started on the engine. I also replaced the cracked defroster vents since the dash is out.
Its amazing I have made this much progess with the little time I have to work on it as busy as I stay. Its also amazing how I stay this busy without a gf ... and i'm sure ya'll know exactly what I'm talking about. If I get dragged into the game, there's no telling when I'll have time to finish this project. Anyways, all in all, my ultimate goal is to have a quick full-interiored automatic.
Old 04-08-2007, 12:32 AM
Linebckr49's Avatar
[borat] very nice, i LIKE! [/borat]
i absolutely identify with you there. i'm busier during the weekends than i am during the week b/c of these cars. and i'm sure these cars would not allow a gf in our relationship .
i was helping (and will be again tomorrow) a friend with his motor swap (92 TT spun bearing) friday and today (saturday). we worked friday evening til 4:30 sat morning, crashed at his place, then got up saturday at 2 and went back to work. took a break to spend some time with my bro who's back in town sat night, Easter sunday morning with the fam, then Sunday afternoon i'll be headed back out to work some more on the car.
earlier friday, i also helped another friend pull his motor/tranny because 1) the timing tensioner pulley broke off its bolt, leaving the other half stuck in the block, and 2) he wants to do a TT conversion.
out of all the work i find myself doing on other ppl's 3S's, i get tired of doing it period and neglect my own car. but i really DO enjoy working on these cars, there just comes a point where i realize all this wrench time seems futile just to maintain a 15 year high performance car. but then i think, duh, its a high performance car, this kind of maintenance is normal, let alone expected for a 15 year old car. also, it makes me NOT want to do the TT conversion, whatsoever. at least there's no way i could see doing it with the engine IN the car, LOL. i think i'll stay NA for now and worry about little things like cosmetics (rims, paint, etc) and little power adders (long headers) and finish my HID retrofit (f*#ckin Dremel broke AGAIN). i can appreciate a daily driven high performance car (though it is NA) that is reliable and starts every day. i'll just get a TT car someday and make it a track car (road course, not that straight line acceleration crap ).
duh! i knew that. i'm not thinking clearly. but Hotshot has the emanage: if its the ultimate, i believe he has timing control, whereas the blue version doesn't. why won't the 93-99 style work on a 91-92 head? all you would have to do not use the adjustable sensor, and put the vane sensing blade between the cam shaft and cam gear sprocket. i bet you could do it, but it makes no sense to do so. anyways, we now know he picked them up for a good deal, not for timing adjustability.
93 3000GT base
Old 04-08-2007, 11:10 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
I'm still holding out for your auto AWD conversion
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 04-10-2007, 07:14 AM
Now that might be a while before I even get to that. On top of that, I would have to find the rear end from a 6-speed.
Whats funny is that for the longest time, me and a friend of mine with an RT/TT had been saying that an AWD ATX would just be sick and totally dominant on the track. Well, 3SX decides they want an AWD ATX for their drag car, and next thing you know, they hold the current 1/4 mile record with it.
Old 04-10-2007, 01:53 PM
...how'd they mate the x-case to the ATX? or did they use a non-3/s ATX?
...or did they get ahold of one from an SR...?
Formerly BlinkRA182
Old 04-10-2007, 02:51 PM
Linebckr49's Avatar
ATX from an SR.
93 3000GT base
Old 05-09-2007, 10:13 PM
i figured i'd post up another update. Right now i'm hung because i'm waiting on stuff. This weekend i've got to work on getting the front motor mount to fit at someone's shop, and i'm still waiting for my Quaife LSD to be delivered. I also pick up my O2 housings this weekend, too. I didn't have much to do tonight so I took some pictures instead:
Old 05-09-2007, 10:25 PM
wtf...no polished plenum? lol
damn man, that is looking GOOD. Makes me hungry...
i would kill to have the tools and space to pull my engine for a rebuild.
Formerly BlinkRA182
