Old 04-07-2007, 04:35 PM
epecenter epecenter is offline
tail housing
i just wanted to know if any one could help me with a problem that i have. my 98 blazet has a two wheel drive tranny and one of my friend gave me a tranny form a 4x4 blazer. i know that the two wheel drive has a long tailhousing and the 4x4 has the transfercase. i just wanted to know if i could swipe the tranny out and if i could install the tail housing from my two wheel drive tranny in to the 4x4 and would that be a direct fit. could any one help me before i remove the tranny and save my self a problem.
Old 04-08-2007, 09:15 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: tail housing
The tail housing will bolt on But.
The 2W tail shaft and 4W tail shafts are different.
You would have to take the transmission apart to change the tail shaft.
Lot of work and if they are different years the valve body may different and wired different.
Here is a link that will give you a idea of what you will get into.
http://72.19.213.157/files/4L60ERemoval.html
MT
MT
Old 04-08-2007, 10:11 AM
Thumbs up Re: tail housing
MT
thank you for the website its very helpfull
Old 04-08-2007, 10:23 AM
MT-2500's Avatar
AF - Advisor
Re: tail housing
You are welcome.
How bad is the transmission that is in it or what is it doing or not doing?
If you get into chaging tail shafts I would consider installing a clutch and seal kit and looking stuff over while you have it apart.
Good Luck MT.
MT
Old 04-08-2007, 11:08 AM
Re: tail housing
You are welcome.
Good Luck MT.
the one thats on my car kicks on the first change of gears and i what to change it before it goes out, i think i could trade the 4x4 tranny for a two wheel drive tranny and save all that truoble, i got the 4x4 tranny because it only had 39000 miles on it.
thank you for the info
Old 04-08-2007, 11:13 AM
MT-2500's Avatar
AF - Advisor
Re: tail housing
It might pay to get it checked on a transmission capable scanner for codes.
Sometimes it is only a solenoid or sensor problem.
If any codes post back code no.
MT
MT
Old 04-08-2007, 11:17 AM
Re: tail housing
MT
the only code that i get is p1870
and a message that says malfuntion manufactor control transmission
i don't know what that means
Old 04-08-2007, 11:28 AM
MT-2500's Avatar
AF - Advisor
Re: tail housing
You need a full transmission/engine capable scanner to check it.
OBD11 will not check transmission problems.
Good luck
MT
MT
Old 04-08-2007, 11:30 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: tail housing
See here for info:
http://www.automotiveforums.com/vbul...ighlight=p1870
Old 04-08-2007, 11:40 AM
Re: tail housing
Good luck
MT
thank you
