Need some opinions.
First off Im new to this forum, and would like to thank everyone for their help and advice ahead of time.
Now to get down to it. Ive always wanted a Camaro, but have never had one. I just got back from looking at a 91 RS for $700 with a prior salvage. It looked like a very clean car. The only rust I found was one spot about 2 in by 1 in on the drivers side rear wheel well. and that same panel had a dent which had been pulled out, but there was still a slight ripple in the metal. Other than that and a few chips in the paint the ext. looked good. It also has one electrical problem the taillights dont work. The brake lights and turn signals are fine, just the night time running tails.It looked to have a new exhaust installed with nice chrome tips. But the biggest problem is it doesnt start. The owner says it was idleing in the drive and it just stopped running. He tried to spray starter fluid in it and it started again for a second then died again. He thinks its either the fuel pressure reg. or the fuel pump. The engine tries turning over when you turn the key but it just wont fire. So my questions are what would you think is the starting problem? And Do you think this car would be worth buying? Thanks or the time and the advice. |
Re: Need some opinions.
If it is the fuel pump, they aren't difficult to install but time consuming. And taking it to a shop will set you back a few hundred bucks. I would keep looking...third gens are EVERYWHERE. Good luck with your search and welcome to the forums!
![]() -2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*- |
I agree keep looking. You don't want to get a car that is going to be a money pit.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering ![]() |
doesn't sound like a money pit to me, more details would help tho, like v6 or v8. testing for fuel pressure and spark will narrow down the possibilities of what the problem is.
fuel pump is very likely tho since the starting fluid gave it life for a second. a way to test is to see if the fuel pump primes, all you do for that is turn the key to the on position and listen for the hum of the fuel pump, if you hear nothing, then it's not priming. but make sure you test the fuel pump relay and check the fuel pump fuse before replacing the pump itself.
The salvage title is what scares me the most.
So should I: A)keep saving, B)grab this one and repair it. Or C)win the lottery and buy a 1969 Camaro ZL-1????????? Last edited by blindeyed; 04-08-2007 at 07:38 PM. |
Also if anyone can tell me some good places to look for decent cheap third gens please let me know. Right now Ive been looking on Craigslist and Ebay, so if there's any others I should take a look at let me know. Thanx.
how hard was it hit? if you dont hear the fuel pump check the inertia switch before digging to far.has it run since it was hit? if you hear the pump (you may not hear it unless you bump the engine over) is it a steady whine? if so buy a cheap pressure tester or borrow if you can. i beleive you should have about 50psi after bumping it over.
Autotrader, Cars.com...there's also classifieds on camarosource.ca.
