Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-07-2007, 02:52 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Tranny question, IDK what it is...
Hey all;
My car has always, when cold, been weird with the tranny. When starting off from a stop, it stutters while in gear until the clutch is fully let off. Also while say driving in 1st or 2nd gear... ok, so im in 1st with clutch fully let go, just rolling at like 2mph and I touch the gas, the car jerks. It's been doing stuff like this more often, even in low 2nd and 3rd. What do you guys think this problem is? Clutch, TOB, Master/Slave Cylinder? I'm hoping for the last one. What are the symptoms of the cylinders going out? I would hate having to drop the tranny.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-07-2007, 04:14 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Tranny question, IDK what it is...
So its almost like your clutch isin't fully releasing when cold. Usually the master/slave cylinders start to leak when they are going bad. Maybe try changing out the clutch fluid and bleeding the system.
My car kinda stutters to when the rpms are low. Mainly in 4th gear around 40mph or so, when im barely on the gas it jerks. But I think that has more to do with the motor than the tranny
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-07-2007, 05:50 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Is it jerking forward or jerking backward?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-07-2007, 06:06 PM
david-b's Avatar
Dave is THAT guy
The car is still moving forward. It's like stop-go-stop-go, just not coming to complete stops of course.
I've drained the clutch and redid it a little while back. Did it before then and had the saem afterward. It's even doing it after normal driving now, like when it's all warmed up and all.
It's really hard to explain without not being there. I'm going to try to take a video and try to see if I can capture the moment. But if I'm starting from a stop letting the clutch off slowly its jerky.
75 Monte Carlo
Old 04-08-2007, 09:21 AM
Holset powered 420a
That sounds like your clutch may be bad. Or something may be warped
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-08-2007, 10:24 AM
david-b's Avatar
Dave is THAT guy
I didn't want to hear that. Gah. I'm trying to stay away from a tranny drop as long as possible. Anyone else have anything else?
75 Monte Carlo
Old 04-10-2007, 10:18 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
how do your motor mounts look?
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 04-10-2007, 11:09 AM
Holset powered 420a
he has the prothan mounts so they should be fine
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-10-2007, 08:33 PM
david-b's Avatar
Dave is THAT guy
ya those mounts are brand new prothane. did it before I had those also.
75 Monte Carlo
Old 04-11-2007, 07:55 AM
Mikelb's Avatar
Ah, I didn't even pay attention to the sig, sry. It does sound like the clutch going to me though... If you are in third gear at a/b 2500-3000 RPM(not sure what speed that is), push the clutch, rev the car, and drop the clutch... if it's going bad it'll slip really bad, if not, it should catch pretty quick.
*Disclaimer: That test may indicate how bad the clutch is getting, though it may also completely destroy a clutch.
