Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-07-2007, 11:45 AM
Rolley Noodles Rolley Noodles is offline
1995 camry
I searched the fourm and havent seen any theads on this problem 95 camry at idle if i press the gas pedal to floor it bogs and dies out and while driving if its gunned it dies out and is hard to start back up any info greatly needed
Old 04-07-2007, 03:41 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: 1995 camry
You need to provide more information. What engine? How many miles on the vehicle? What maintenance has been preformed on the vehicle and when? Has anything been changed on the vehicle recently? When did these symptoms start? Does it bog down when the engine is cold or warm or both? Help us to help you.
Mike
Old 04-08-2007, 06:55 AM
Re: 1995 camry
its the 5sf and it does it when hot it seems to be running out of fuel
Old 04-08-2007, 07:09 AM
snupytcb snupytcb is offline
Re: 1995 camry
does it only do it under a load? you need to check fuel pressure while it's acting up. the pump may be getting hot. also if its possable check voltage at fuel pump at same time. i have seen the alt over charg and do the same thing.
Old 04-08-2007, 11:23 AM
AF -Advisor
Re: 1995 camry
Mileage? Maintenance?
I agree with snupytcb; check fuel pump pressure. Also, since it does it hot, check the engine coolant temperature sensor (Toyota calls it an ECT sensor) with a DVM and the specs from any manual.
Mike
