Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-07-2007, 12:43 PM
unique88 unique88 is offline
Hesitation at low RPM's
I have a real bad hesitaton at low RPM's, usually in 1st and 2nd gear and I'm not sure why. My check engine light came on yesterday but I'm pretty sure it's my 02 because now my air/fuel gauge isn't working. Any ideas on would it could be? Messed up TPS, IAC? Please give me your thougts.
1995 Eclipse GSX
GT Ported Manifold|3" Turbo-back Exhaust|Big 16G Turbo|Walbro 255lph Fuel Pump|FMIC|Lower IC Piping|KoyoRad Radiator|K+N Air Filter|Super Sequential BOV|Greddy Boost Gauge|Greddy EGT Gauge|Autometer Air/Fuel Gauge|Greddy Profec Type-S|Tien Lowering Springs|Toxico Struts|18" 5Zigen Rims|Recirc. Kit for SSQ BOV|550cc Injectors
Old 04-07-2007, 02:30 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Hesitation at low RPM's
Swing by autozone and have the code pulled, then post up the code.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-07-2007, 09:42 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Exclamation Re: Hesitation at low RPM's
Common sense here. A/F guage is not working can mean mostly 2 things; 1) bad connection, or 2) no O2. It seems however that with no O2, the car would run a lot worse then you're saying it is. There's a third option too, your gauge just doesn't work period. But I would have a hard time believing that a gauge would burn out or go bad, unless wired incorrectly, which I'm thinking may make option 3 more of a reality for you.
"Any ideas on would it could be?".... Towards what? The car is throwing a CEL and your O2 is apparently not working. Get the CEL pulled and fix that problem. Why are you coming up with random parts such as the TPS and IAC? IAC will cause bad idle, and the TPS will cause problem when actually on the throttle. Ok, maybe for the hesitation the TPS may be a problem there, but you answered your own question. Anytime the CEL comes on, get that checked out right away, fix that problem, and then post about problems. It's easy. I hate these threads.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-07-2007, 10:37 PM
Didn't mean to piss anyone off. I was just simply asking if this was a common thing. Apologies.
1995 Eclipse GSX
Old 04-07-2007, 11:30 PM
david-b's Avatar
Dave is THAT guy
Sorry dude. Bad evening. Everything still goes as before. See what the CEL is saying then go from there. Sorry to come off like that.
75 Monte Carlo
Old 04-08-2007, 01:17 AM
Will do. I'll let you guys know.
1995 Eclipse GSX
