Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 04-07-2007, 09:35 AM
motfu motfu is offline
Exclamation 1500 HD passenger door electrical problems
2003 Sierra 1500 HD - passenger door electrical components (lock, window, mirror) are inoperative. Keyless entry, mirror fold function, Retained Accessory Power (RAP), and window/door lockout switch are also inoperative.
I know from other forums that this is a fairly common problem. However, those forums did not provide a good solution. Some solved by disconnecting battery/fuses/relays (supposedly to reset the body control module/truck body controller). That didn't work for all. Others replaced the BCM/TBC but I'm not sure if that fixed their problems.
I have check all fuses. All good.
I could not locate the RAP relay or 50A fuse. Does anyone know where they are?
Does anyone know if these are symptoms of a malfunctioning BCM/TBC?
Any help would be appreciated.
Vehicle details - 2003 GMC Sierra 1500 HD, 6.0 L, Automatic Tranny, center console, towing package.
Old 09-04-2012, 09:22 AM
Ranger0001 Ranger0001 is offline
Re: 1500 HD passenger door electrical problems
Did you ever figure out this issue with the passenger door electrical and keyless remote not working. I have the same problem with my 2007 Sierra pick up. The window is down and it's now raining.
Thanks,
