Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 04-06-2007, 09:44 PM
banffboating banffboating is offline
94 7.4L no spark
Help I was driving and all of a sudden lost power and back firing but would idil fine just no power got a code low voltage fuel relay changed out fuel pump
truck ran fine two weeks then did the same thing I was far from home went to a parts store got a new ecm and fuel pump relay but this time lost spark from coil ! will not start
Old 04-07-2007, 08:25 AM
maxwedge maxwedge is offline
A990 racer
Re: 94 7.4L no spark
Welcome to AF. TBI, I assume. Got 12v to coil, correct? Suspect module or pick up in dist.
Old 04-07-2007, 07:45 PM
I replaced the module now it runs but back firing from carb at higher rpm and seems to be missing the distrbuter shaft has no play in it!
Old 04-08-2007, 08:36 AM
A990 racer
Fouled plugs, cracked cap, switched wires, bad coil or wires, are some possibilities.
