Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 04-06-2007, 06:43 PM
juggalojesus87 juggalojesus87 is offline
Question high idle
my fiero is idleing high... starts out at 2.5 rpm then as it warms up it lowers and stops about 1.5 rpm. it runs this way till it gets hot then when you push you gas it boggs out like its choking and wont go any faster than the idle... the computer is not pulling anything up but i think i have a vacuum leak but not sure... cant tell from the leak in the exhust manifold leak because the bolt broke off in the head... ... any input would be apreciated
Old 04-10-2007, 06:31 PM
Re: high idle
fixed the high idle ( broken egr tube) but still when i drive for 10 or 20 min it starts to cut out when i accelerate/press the gas or rev up... the longer i drive the lower i can rev up. any ideas? im thinking fuel pump/ low fuel pressure...
Old 04-10-2007, 06:35 PM
snupytcb snupytcb is offline
Re: high idle
have you done a tune up including fuel and air filter?
Old 04-10-2007, 08:44 PM
Re: high idle
wires are good. plugs... been a year... fuel pressure to be checked tomorrow. fuel filter was replaced a year ago... air filter is a k&n might need recharged.. but dont think its bad. dis rotor was replaced year ago along with timing. the cap was replaced at the same time.
Old 04-11-2007, 01:04 PM
Re: high idle
just did a fuel pressure test and with the car on and key turned it reads no pressur. but with the engine started idleing it reads 36psi and when car turns off it drops back to 0
Old 04-16-2007, 05:41 PM
'88 Dread GT's Avatar
'88 Dread GT '88 Dread GT is offline
Re: high idle
My '88s doing that now... It starts right up and idles at 2200rpm. It warms up after about 7-8 minutes then goes to 1300. Once it does this it sets a code 35. Yup, sounds all too familiar. Unfortunately for me the EGR tubes for '88s are no longer available. My original broke 11 years ago and I've had an '85- '87 donor EGR tube since and now I believe it's finally cracked. Can't complain about how long it's lasted...
Anyway, my spring project is to replace all my vacuum lines. I bought the Rodney Dickman stainless steel lines that run under the upper intake plenum(my originals are 19 years old, plastic, and very brittle), new AC Delco vacuum canister, rubber tubing where needed, and Fiero Store's flexible braided steel EGR tube. I'll let everyone know how it works out in a couple weeks.
=-Dread
