Old 04-06-2007, 03:55 PM
JBMark33 JBMark33 is offline
Send a message via AIM to JBMark33
Miscellaneous problems
1. the brake pedal itself sqeaks when i put so much pressure on it.. what possible things on the pedal could be making this noise?
2. Red Low coolant light on, checked reservoir = full, temperature guage is normal car runs normal... bad sensor?
Old 04-06-2007, 07:55 PM
panzer dragoon panzer dragoon is offline
Re: Miscellaneous problems
xxxx
Condition
Some customers may comment that the low engine coolant level indicator is always illuminated.
Cause
The cause of this condition may be due to engine oil contaminating the coolant. Possible sources of oil contamination are internal engine leaks, improper service procedures, or the addition of some types of anti-leak additives to the cooling system. Once in the coolant, the oil leaves deposits on the level sensor creating an insulating film. This film results in a false activation of the coolant level indicator.
Correction
Diagnose low coolant level system operation and check the sensor for oil contamination using the procedure listed below.
Important: No coolant supplements should be used in GM cooling systems, other than what is approved and recommended by GM. The use of "aftermarket" over-the-counter sealing and cooling supplements may affect the operation of the low coolant level sensor. Discoloration of the coolant recovery bottle is normal and does not necessarily indicate that coolant contamination is present. Flush cooling system only when instructed by this bulletin.
1. Verify that the coolant is at proper level in the radiator and the coolant recovery bottle. If the coolant is low, add proper amount of 50/50 water and DEX-COOL(R) mixture. If the low coolant light operates properly, diagnose the cooling system for loss of coolant as outlined in SI. DO NOT proceed further with this bulletin.
2. Remove the low coolant level sensor. Refer to Coolant Level Module Replacement in the Engine Cooling sub-section.
3. With the key on, the engine off and the coolant level sensor disconnected from the vehicle wiring harness, observe the low coolant light:
^ Light is on - Chassis wiring or instrument cluster concern. Follow the appropriate diagnostic information in SI.
^ Light is out - Proceed to Step 4.
4. With the key off, connect the coolant level sensor into the vehicle's wiring harness. Connect a ground wire (1) to the battery negative terminal. Using a sharp probe (3) attached to the ground wire, ground the coolant sensor probe (2) as shown in the illustration. Make sure a good contact is made. With the key on and the engine off, observe the low coolant light for at least 15 seconds.
^ Light is on - Replace the low coolant sensor and re-check system operation.
^ Light is out - Proceed to Step 5.
5. Using a small wire brush or emery cloth, polish the low coolant level sensor probe to remove any film or oxidation. The probe should be a bright brass color when finished. Use Brake Parts Cleaner to flush removed deposits from the low coolant sensor probe. Re-install the low coolant sensor into the vehicle and proceed to Step 6.
6. Flush the cooling system and install new DEX-COOL(R) mixture as outlined in the SI. Check the vehicle's warranty history to determine if any engine gasket had recently been changed. If there has not been a recent gasket replacement, locate and repair the source of the engine oil contamination.
-I changed the picture 4/7
Old 04-06-2007, 09:52 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
That diagram doesn't make sense. The procedure is for checking the coolant level sensor, and the diagram is a picture of the coolant temperature sensor. The coolant level sensor is in the bottom of the coolant surge tank.
2003 Pontiac Grand Prix 3.8 Litre V6
ASE Certified Master Tech
Old 04-07-2007, 12:48 AM
If it helps it's a 3.8L... I am thinking the sensor myself because the car runs normal, and the hoses to and from the radiator and the thermostat housing are full and warm and the temperature is normal. Like i said, reservoir full. When i first start up the car, its fine. When i start driving it, it stays off for about 30 seconds, then comes back on. As soon as it quits snowing for 20 min. I am going to try to take the reservoir out and check out the sensor. Thanks for the replies.
Old 04-07-2007, 12:53 AM
Speaking of snow... what else is annoying is slush builds up behind the drivers front wheel well behind the mud flaps, and when it freezes the one clamp comes out so when i turn, the flap gets pulled out and onto the side of the tire!! oh soo annoying!
Old 04-08-2007, 12:20 PM
I think when i added coolant, it stirred up some gunk in the reservoir and covered the sensor most likely, the light has not been on for a day or two now. Thanks for the replies!!
