Old 04-06-2007, 02:36 PM
Tonyyy Tonyyy is offline
92 Bravada won't start warm
Engine starts great when cold. After fully warmed up, it cranks but won't start unless I push the gas peddle all the way down and hold it there while it cranks and then it starts and will run fine if it idles for a few seconds before putting in drive.
Old 04-06-2007, 03:34 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 92 Bravada won't start warm
You might start with checking for codes.
How is the base timing?
Any check engine lights?
MT
Old 04-06-2007, 03:55 PM
Check engine light does not come on with this problem.
Old 04-06-2007, 04:45 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Might sound crazy but possible catalytic converter. Cousin had a jeep that ran fine until it warmed up then it fell flat on it's face until the cat was swapped. I am probably completely wrong but something worth checking
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 04-06-2007, 06:48 PM
MT-2500's Avatar
AF - Advisor
Not all problems set a check engine light but a good scanner check may show the problem.
And as said check the cat. A good vacume gauge will show a cloged cat.
Also a good fuel pressure check may show something.
Good luck MT
MT
