Old 04-06-2007, 02:49 AM
LTZ9C1 LTZ9C1 is offline
Unhappy Buzz/Grinding electrical noise coming from dash
I have a 2000 S-10 2WD and I've had this buzz, grinding electrical kinda sounding noise for the past 4 years.
At idle I can hear it but more once I accelerate and gets louder when I let off the gas pedal. It starts to grind and buzz like an electrical transformer would after getting hit by lightning.......annoying like a mofo
Any clues what is making this crazy noise? Dealerships are stumped also.
Thanks in advance.
Old 04-08-2007, 09:08 AM
muddog321 muddog321 is offline
AF -Advisor
Re: Buzz/Grinding electrical noise coming from dash
I'd look at a few of the common stranger things that I have had.
1. PCV valve rattle mormost at idle comes along the throttle cable if the plastic tie down on the drivers side of the intake breaks off - common after lower intake done. Resecure and possible PCV valve replace if aftermarket and check the valve cover grommet - yep it happens.
2. 99-01 have secondary air injection and that has check valves in the exhaust manifolds that always fail - internal spring and also rust out - see info in the How To on these.
3. Now if a more gurgaling sound thats the heater core.
4. Then possible relay chatter so listen in the underhood block or behind the glove box is the flasher/blinker one.
Hope its one of them!
Old 05-02-2007, 12:34 AM
Talking Re: Buzz/Grinding electrical noise coming from dash
Thanks, problem solved.......FINALLY!!! opcorn:
It was the throttle cable hitting the PCV valve. The dealership said it was my fuel pump.......bastids!!!
Thanks a ton again
