Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-05-2007, 10:57 PM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
2G eclipse with a 6 bolt motor
Needless to say, I had a motor rebuilt for me and requested it to be a direct bolt up to a 97 eclipse gsx. I went to pick it up today after waiting a month for it and there was a nice shinny 6 bolt motor waiting for me. Well, besides the fact I know about the crankwalk on a 7 bolt, I just wanted a simple replacement.
I agreed to take the motor and discussed the changes, will be getting the necessary parts free of charge, since it was not my mistake. The block and head are both from a 92 eclipse. The obvious change would be the 6 bolt flywheel but what other parts must be changed or altered for it to fit correctly.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 04-05-2007, 11:18 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 2G eclipse with a 6 bolt motor
Do you have a point?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-05-2007, 11:24 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I think he wants a list of all the parts needed to do the swap.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-06-2007, 12:31 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Can I barrow 50 cents?
DSM geek
Old 04-06-2007, 01:02 AM
and no you cannot barrow 50 cents.
From what I had been informed of, the water pipe, water pump, flywheel, oil filter, oil filter housing, CAS, and thermostat housing are different. Also some grinding on the mount may have to be done. I was just attempting to see if there are other changes or parts I may have to go and buy or swap out also. I guess I may find out on my own as I piece this jigsaw back together, but it would be nice if I got some heads up.
Thanks
72 Beetle - trashed
92 Talon - sold
Old 04-06-2007, 01:20 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Check out my project thread listed in my sig... I have pictures and information of the things that are needed to put the 6 bolt into a 2g... I am almost done with the project too so you will find "most" of the info there... I am just getting to wiring everything up now, so I haven't listed any electrical changes yet.
**EDIT**
Most of the info geared towards the differences are on the last few pages of the thread... I gotta get a cleaner version of that thread put together as a write-up when the entire project is finished.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-06-2007, 09:48 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Here is a good write up with all the differances
http://www.magnusmotorsports.com/tech/index.htm
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 04-06-2007, 10:00 AM
thanks for the info, that is exactly what i was looking for but having trouble finding
72 Beetle - trashed
92 Talon - sold
Old 04-15-2007, 07:21 PM
are the flywheel bolts exactly the same with a 6 bolt and 7 bolt, as in size
72 Beetle - trashed
92 Talon - sold
Old 04-15-2007, 07:42 PM
Yes, I stole the bolts from my 7 bolt for the 6 bolt when I was putting it back together.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-15-2007, 08:43 PM
just wondering, ive already tried that, but i was wondering if the length of them was longer in the 6 bolt style. I put one in all the way and it seems like there the hole is about 4mm deeper than the lenght of the bolt, though they are the same thread and width. I dont remember if my 7 bolt had the same gap.
72 Beetle - trashed
92 Talon - sold
Old 04-15-2007, 08:54 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The hole is 4mm deeper than the bolt? That sounds about perfect to me.
95 Talon TSI AWD
97 Eclipse GST
Old 04-15-2007, 09:31 PM
WaFFeL WaFFeL is offline
As long as it goes all the way in whats the problem
Old 04-15-2007, 10:53 PM
The more threads holding it, the better...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-16-2007, 01:45 AM
ive came across some other differences though, mainly with the timing side. of course, i still have a 2g tensioner and tensioner arm. The tensioner is the 97 up version where it has a single bolt on each side, so I need the other one. I was also told the arm could still be used, if you shave some of the water pump... sounds risky though. could the arm be trimmed to fit? I know the tensioner isn't adjustable in height like it is on the 420a motor. is the arm on the 1G a different lenght?
72 Beetle - trashed
92 Talon - sold
