Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 04-05-2007, 10:26 PM
electricmanbob electricmanbob is offline
'93 Roadmaster ABS - $$$$$
My ABS light lit up on the dash. The error code was for the pump/ valve assembly. I checked it out and the motor on the pump wasn't working. It's a sealed unit. Here's the kicker the only ABS hydraulic unit I could find locally was at the BUICK dealer, new for $2,058.00 . The internet has rebuilts for $657 plus a core charge. I'm the original owner, bought it in Sept. of '92, it has just under 64,000 miles and is almost mint! I went to the junkyard and bought one for $125 +tax. 90 day warranty. I cleaned it up and went to install it, but couldn't get one of the brake lines out of the unit. I'm going to see if I can get a preformed replacement line tomorrow, otherwise I'll have to bend one. It's still cheaper than the two grand for a new unit. I've only replaced a starter, water pump and radiator. as soon as I get the ABS fixed I'm selling it - it's been a fantastic car, but I'm afraid it's going to start costing me more than it's worth.
Old 04-06-2007, 11:20 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: '93 Roadmaster ABS - $$$$$
That's too bad. These are great cars and hold up quite well. If you look back at the track record over the 14 1/2 years you've owned the car you'll soon realize that not a lot went wrong and you didn't spend a lot of money keeping it running. These cars are capable of over 200,000 miles and even if you have to put in$1000 a year, it's still cheaper than buying a new or fairly new car these days, and besides that it's built better and safer.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 04-07-2007, 12:30 PM
I ended up heating the brake line fitting with a propane torch for 10 minutes and got it loose with a vise grip. I figured I had nothing to lose by trying to tighten it in the new unit with vise grips. it worked ! T he Junkyard unit works fine. It ended up costing me $149.31 with the brake fluid. I would like to keep the car until it hits 100,000 miles, but we only drive it 2500-3000 mi/yr.
I'd be 93 or dead by then...............
