Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 04-05-2007, 08:24 PM
Sleeper75 Sleeper75 is offline
Rear end conversion
I have a 1975 Nova with the L6 auto. Im going to be putting a 425+ hp 350 in soon and im not sure what to do about the rear end. I have been told a ford 9" will work and that that is the best alternative. Im looking for a cheap reliable solution to positraction problems.
All help appreciated.
Thanks
Old 04-09-2007, 09:50 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: Rear end conversion
I've used a Ford 9" rear under a few Novas. There is no real cheap way to do it since the conversion should be done by a competent fabrication shop. You'll also want the axles swapped out or drilled for the Chevy bolt pattern. If you can find a good used Ford posi unit, that will save some bucks.
An alternative is to pick up a 12 bolt Nova rear, which will bolt right in and save the fabrication costs. I'd suggest after market axles and a c-clip eliminator kit for it.
Whatever you decide on, spend your money ONCE. Do it right the first time. If you have a local speed shop, many of they have a bulletin board where people post things for sale or swap. You might get lucky.
Bob
