Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 04-05-2007, 07:25 PM
rapposm rapposm is offline
Angry P1582 Code and Catalytic Coverter
I own a 2000 VW Jetta and just resently my Catalytic converter went bad, not yet replaced, and now the check engine light turned on and is giving me the P1582 (Malfunction Vehicle speed control) code. I have cleaned the throttle body and also replaced a bad hose, cleared the code and it came back.
What I need to know now is can a bad Catalytic convert cause the P1582 code.
Old 04-08-2007, 06:29 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: P1582 Code and Catalytic Coverter
What engine?
The AEG engine has an extended warranty till 120k miles
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 04-08-2007, 08:33 PM
Engine size 2.0L, Model GLS, 225000KM.
Old 04-13-2007, 11:57 AM
VDUBMAN
If there is a rattle from under the car when slowly revving from an idle than the cat is most likely the cause. The material inside breaks up and rattles arround in the exhaust.
Old 04-26-2007, 07:12 AM
Yup it was the Catalytic that was causing the P1582 code> Chnaged it, turned on the Check Engine light, and the car runs great now.
Old 07-30-2007, 03:42 PM
BEAVIS18 BEAVIS18 is offline
Send a message via AIM to BEAVIS18
yeah my girlfrend's jetta had same thing wrong with it put a new cat on but the check engine light is still on after the computer was reset
