Old 04-05-2007, 04:14 PM
4twenty's Avatar
4twenty 4twenty is offline
D16Z6 92 civic motor into CRX?
Is it true that the D16z6's intake manifold doesn't match my throttle cable and stuff, and that i'll have to use my intake manifold? and also, which axles/ecu would work best with the D16z6 92 civic si motor?
Old 04-05-2007, 07:36 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: D16Z6 92 civic motor into CRX?
i hate to be queer like most of the girls on here..but do some research..all ur questions can be easily answered..its like asking if a d15b2 can be swapped out for a d15b1 or w.e use the search! p.s =) if u cant find urself a decent si tranny u will have to do a hydrualic conversion
Old 04-05-2007, 07:38 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
I dont believe that there is a problem in using the z6 manifold. Although there is no harm in using the stock one. My d15b is using the stock manifold without problems. you can use your stock axles, and go with a p28 ecu.
Old 04-06-2007, 01:04 AM
4twenty's Avatar
well fuck, i was gonna get a ZC head for 425 canadian and jus bolt that bitch up, but my boy told me his cousin was dropping his engine from his 92 bubble back and hes willing to sell me the whole thing with tranny for 3 bills... it not as much hp but still... which would you do???
Old 04-06-2007, 08:24 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
ZC sohc non-vtec or vtec? If it's the ZC sohc vtec it's about the same as a d16z6. If it's the non-vtec it's about the same as a d16a6 (maybe 2hp more). If it's a ZC dohc head it won't fit a sohc block. If it's a ZC dohc long block it'll swap in and mate to a d tranny.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-06-2007, 10:39 AM
4twenty's Avatar
lol what the f are u talking about??? my bad i wasnt clear before... i have 2 options - option A: spend 425 dollars on a DOHC ZC non-vtec 130-135hp block, just the the block (which bolts up to my tranny) or option B: spend around 300 dollars on a whole 92 bubble back civic si vtec motor with tranny. i didn't mean to say "ZC head" i meant block... i was a little hammered last night... hahaha
