Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-05-2007, 04:47 PM
THXbox THXbox is offline
No heat
My '96 Talon , which just had a new thermostat and radiator flush in December , is again showing the same signs of trouble . The temp. gauge isn't coming up and there's no heat at all . Last time this happened , it ended up with the car being un-able to stay running , and about $ 400 worth of work . Any ideas what could be going wrong this time .
Old 04-05-2007, 10:46 PM
neilmac78 neilmac78 is offline
Re: No heat
may sound dumb but did you make sure coolant was full or all air was out.
Old 04-06-2007, 01:55 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: No heat
Did you remember to hook up both coolant temp sensors when you installed the thermostat? There are 2 of them on the housing, one for the ECU and one for the gauge. If the ECU never sees the vehicle reaching operating temp, you will be running around in limp mode.
Do you have access to a logger? If so, you can check out the coolant temp. But since it sounds like both sensors are dead, since the car is running crappy and the gauge isn't moving, I would look at the thermostat you just installed. What was the temperature rating of the thermostat?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
