Old 04-04-2007, 08:50 PM
jeep89 jeep89 is offline
89 cherokee cold air intake
I have a 89 cherokee 4.0L v6 and want to do a intake. I have seen the brakets you can get and put a cone filter on but that means getting rid of the air box all together. I heard this was bad for this motor. So I was wondering if the airaid intake part#AID-310-136 from summit racing would work. The only thing is it is for 91 and up. Is there really anything different about the 91 engine wise.
Thans a lot in advance
Jeep89
Old 04-05-2007, 07:26 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 89 cherokee cold air intake
I think the 91 was the "high output" year where you got another few hp.
Putting an intake on the engine shouldn't hurt it, I would think it would actually help it.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-06-2007, 06:41 AM
sector95 sector95 is offline
Personally I think those intakes are just a great way to give someone else a great deal of your money for not much in return. The major bottle neck in the intake track of the engine is the 90deg bend to connect the air intake to the throttle body; none of the aftermarket kits eliminate that bend (physically impossible because the hood line is low and the engine is mounted high.) I've always wondered why no one has invented an intake mounted to the hood...sort of like a shaker hood used back in the 60's and 70's.
If you really wat to put something other than the stock unit in place, you can easily make your own....do some googling on the subject befor you drop 300 in coin. I made one using a 3 inch diameter peice of exhaust tubing (available at AutoZone, etc) and a K&N cone filter.....cost about $100 and that's only because the K&N was so expensive. In the end, I removed it because it: A) seemed to provide no "seat of the pants" improvement in anything (acceleration, gas mileage) and B) because it made the already loud engine even louder.
mike
00XJ
