air cond. not working
my 97 lumina air wont work.. the compresor wont even click. relay checks ok.. was ok last year.. i just put an intake gasket on, mabe i knocked a wire off.. any help..
Re: air cond. not working
Make sure you didn't forgot to hook up a ground wire...probe the compressor's pigtail with a test light and see if you have a ground but no hot, or hot and no ground when it's on...then you'll know at least which is the problem.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
Make sure the pigtail didn't just get corroded over the winter too...happens occaisionally...you pull the plug off and put it back on, and it starts working...
Yes there is a low pressure cutoff switch...won't let the compressor run if the system is too low...
I'm afraid to suggest any more...I haven't worked on A/C systems since they got more complex and had connections to the ECM (which is why I suspect it died when you crossed it up)...
If one wire coming off the switch matches one at the compressor, I'd think that should be the one you need to to jump power to...did you verify ground at one side of the compressor plug?
You can get an R134a recharge kit very cheap and shoot it, just to see if it will start up and run, or starts blowing out of the system like crazy somewhere.. If the system is so low that the compressor won't start, then just the pressure of a charge can hooked to it will bring system pressure up high enough to close the low pressure switch and start the compressor...may take a few seconds to a minute before it does, but I've not seen one fail to start unless there was something else wrong...running cold water over the condensor will make it draw it in faster too... If you have power as far as the low pressure switch, and you were able to start the compressor directly, it sounds like the system is low charge or the switch died...I doubt the ECM is involved...
R134a...I suspect you are using the term Freon generically, but just in case...
Good luck, tell us what happens...
If you have any more, try putting it in with the engine off so you can hear it blowing out...have a door open too in case it's the evap core..
Deos your recharge kit have a gauge? Does it show static pressure in the system with the motor off? How much?
