Old 04-04-2007, 05:34 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
EGR removal?
i was on a site and it said that removing the EGR causes your engine to heat up?! it said the egr prevents a little combustion so that it doesnt heat up as much... anyone know anything about this?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 04-04-2007, 05:52 PM
poormillionaire2 poormillionaire2 is offline
Re: EGR removal?
I could see that as being true. EGR displaces some air in the combustion chamber for a comparatively smaller combustion process. So, replacing that exhaust with more air (and fuel) would yield a better/bigger combustion process. I can't see it making that big of a difference as far as heat though. The EGR shuts off at WOT anyways so it wouldn't be any hotter/cooler there either.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 04-04-2007, 06:12 PM
Re: EGR removal?
ic... anyone who did it before?
hard?easy? im gonna do the IAC, so i figured while im at it i might eithier take out or change the EGR valve..
Car:
285's in the back
all else = STOCK.
Old 04-04-2007, 07:10 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: EGR removal?
The EGR is your friend, unless it's broken, then I'd suggest leaving it alone. But it's up to you. If you're really curious, try taking it off for a while to see if there's any noticeable difference.
Some insight:
http://en.wikipedia.org/wiki/EGR_valve
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 04-05-2007, 09:21 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: EGR removal?
I do believe without some flinagleing (tuning otherwise) of the PCM, you are going to have some issues.
Old 04-05-2007, 09:25 AM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: EGR removal?
im sure it will make the car ride like ass! u cant take anything off and not have something go wrong....
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 04-05-2007, 09:27 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: EGR removal?
if you replace the exhast with long/short tubes and a new system, doesn't that remove the EGR system?
Seatbelts Saved My Life
Old 04-05-2007, 09:28 AM
philly rs's Avatar
Re: EGR removal?
he didnt say he was gonna do all that, im taking it will somehow be deleted...unless im not awake enough, i could be brain dead lol
Old 04-05-2007, 09:34 AM
Re: EGR removal?
I'm deleting mine when I get my stuff from Formula. I already have the blockoff plates, I just need to get to the header provision. Its a tight spot back there...
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 04-05-2007, 01:00 PM
Morley Morley is offline
Re: EGR removal?
EGR deleat on an OBD II is a little bit more involved than on OBD I. You'd have to send your PCM out to have it reprogrammed (or invest in an expensive programmer). If you just remove the EGR you'll get the SES followed by reduced ignition timong and a loss of power.
EGR is actually a GOOD thing to have on a modern engine. It started out as a pollution control but car mfg's soon found out that it had an even better use..cooling the combustion chambers to combat detonation. If you modify an engine and deleat EGR you'll probably end up with pinging, and without EGR, no easy way to stop it.
Old 04-05-2007, 01:25 PM
Re: EGR removal?
Eh...I'm not worried, he's tuning it for me and I'm running a cooler t-stat. But you're right, its an OBDI car.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 04-05-2007, 05:32 PM
Re: EGR removal?
hmm ic. damn, i hate the thought of used up gas coming back.. but anyway, how often does those EGR's break down?
Car:
285's in the back
all else = STOCK.
Old 04-12-2007, 11:46 AM
macker914 macker914 is offline
Re: EGR removal?
DAMN COMPUTERS!!!!!!!!!!!!
GO CARB!!!!!
EZ Online Mechanic
Ryan
'91 Chevrolet Camaro wit da Kenwood Hot
433 Stroker SBC (go-getta)
Old 04-12-2007, 02:40 PM
Re: EGR removal?
haha i would if i had more $$ for the upgrades needed to bump the power back to EFI range, and if i had enough $$ for GAS. >_<
Car:
285's in the back
all else = STOCK.
Old 04-12-2007, 02:42 PM
Re: EGR removal?
EZ Online Mechanic
Ryan
