Old 04-04-2007, 04:25 PM
gregg159753 gregg159753 is offline
Incorrect Temperature Gauge
What would cause the temperature gauge to read off by so much? When my engine is fully warmed up, verified to be running around 190 degrees by a scanner, the gauge in my cluster will be only reading about 150 degrees ( the 2nd line on the left half of the gauge. I've replaced the temp sensor and the temp sending unit.
Gregg
1996 Blazer LS 4DR
4.3L w-code
Old 04-04-2007, 05:34 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Incorrect Temperature Gauge
Scanner tempt reading could be off to.
Get the old or new type thermometer out and see what the real engine tempt is.
Did you change the tempt sensor for the gauge or the VCM?
Or the temp gauge in dash?
MT
Old 04-06-2007, 12:11 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
For as cheap as it is I would replace the thermostat and the gasket and possibly the rad pressure cap total of under $15 american and see if that changes anything.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
