Old 04-04-2007, 03:54 PM
rusted rusted is offline
Tire Pressure; per Honda
So I've looked at a few CRX's including my own, and none have a tire pressure spec on the door jamb. Nor is it in the glove box.
I've checked 2 service manuals as well; silence.
What inflation pressure do you run, and where did you get that value?
[I know the MAX pressure shown on the sidewall is just that; not the car-dependent specification.....]
Old 04-04-2007, 04:51 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Tire Pressure; per Honda
Uhh..on the tire..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-04-2007, 06:26 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
I run like 28-30 on each tire, thats what it says in my glove box (91 si). Keep the spare inflated to like 60 psi.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-04-2007, 06:27 PM
ironman85's Avatar
ironman85 ironman85 is offline
Send a message via Skype™ to ironman85
wha? car specific? thought it was tire specific..........casue if i am on 70% sidewall...and your on low profiles, you will need a higher pressure then me.....
'91 Honda Accord: 2" drop, 5 spoke bronze 17's
CURRENT PROJECT: 89 DX hatch. soon to come --> full suspension upgrades, b20 swap and boost
Old 04-04-2007, 07:16 PM
FrodoGT's Avatar
Yeah man, your car doesn't care what tire pressure your running..the tire does. The tire has a weight rating and a pressure that it is meant to hold for a given weight and tire spec..etc etc..the pressure on the side isn't really the max, its the recommended tire pressure.
Current project:
Rio Red 91 hatch.
Old 04-04-2007, 07:47 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
tire pressure is almost entirely about personal preference...
Although, as you go lower than 30psi, you're likely to develope a tire vibration problem (I see this at work all the time).... also the lower the pressure the more flexable the tire... also the lower profile tire you run the higher pressure you should keep your tires (seriously prevents bending and screwing up wheels from pot holes, to an extent).... I keep my tires at 35psi right now, with stock sized 'performance' tires.... when I had my low profile tires (40 series) I kept the pressures closer to 37-40psi.
30psi or there abouts is highly recommended.... anything above that is purely personal ride feel preference.
Honda Enthusiast
Old 04-05-2007, 09:10 PM
The tire spec is the maximum safe pressure; but that may be way too hard for a given car. For example, remember the Ford Explorer rollover fuss several years ago? Ford wanted the pressures lower, for a soft ride, but the tire mfgr wanted higher. At the lower pressures, the tires failed more often.
The correct answer takes into account both the tire size and the vehicle involved.
Old 04-05-2007, 09:54 PM
ironman85's Avatar
yea, so when they DIDN"T go with firestones recomended pressure....they failed.
go with whats on the tire lol
Old 04-06-2007, 12:14 AM
Killa_CRX's Avatar
When Civics Attack!
Actually, both companies have been found at fault, so far. Firestone for defective tires, that on a long enough time line would have failed anyways. And Ford for a lower than specified pressure (26 instead of 35) which accellerated tire failure (lower pressure, more flexable the tire, the more the tire flexes the more heat is created, the excessive heat caused the tread sepperate fairly quickly).
That was just plain stupid of Ford though... for a vehicle that heavy, I'd never run that low of tire pressure... that's just asking for trouble. But they weren't the only ones at fault, because the goodyear tires that were used, with the same pressure settings and recomendations, hardly ever failed.
Honda Enthusiast
Old 04-06-2007, 12:31 AM
BUT more tire pressure both made the ride harder, AND made the vehicle more squirrelly/less stable, and raised the CG. Big issues: Ford built Exploders on Ranger truck frame, cheaper but higher CG and [and this appears to be underaddressed..] flipping should not be fatal.
There's a NOVA episode that shows the Mercedes convertible on the Autobahn; it flips at ~200Kph and slides upside down for ~1km and flips upright again. The driver opens the door and gets out....
But we've drifted off my OT, which was what Honda spec'ed...
Old 04-06-2007, 08:29 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
I think pressure is tire dependent depending on the wheel size and specific application. With my 14" wheels I used 185/60-14 tires... when new 38psi, when started putting miles on them I kept them at 36psi, when I wanted to ride on tarmac and dirt I kept them around 34-36psi, when I wanted to launch hard with minimial wheel spin and slip the clutch I rode at 32psi. By the time the tires were rotated 4 times with the various driving I've done the tires were pretty well done for. I only had an inch drop so camber wasn't all that bad. Basically, I've found out that the lower the pressure the better the traction for launching, the higher the pressure the more wheel spin from a standing start. Somewhere in the middle gave the best of both worlds.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
