Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-04-2007, 03:52 PM
aSyLuM32 aSyLuM32 is offline
Eclipse GSX Turbo Upgrade HELP
I have looked all over the internet for information on this but haven't really been able to find any solid answers, but im sure someone on these forums will be able to help me out.
Alright, I recently got a 96 Eclipse GSX, and obviously, I want to get a bigger turbo.
What medium price range turbo would you guys reccommend?
And what all do I have to do to make sure that everying runs well with the new turbo? I don't want to mess up the car because I am on a bit of a budget.
Old 04-04-2007, 04:50 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Eclipse GSX Turbo Upgrade HELP
First off, welcome to the forums. Please use the sub forums for your questions and give a quick search before asking a question as it may have been answered to great length already.
It all depends on your goals, what are you looking to do with the car? How much power do you want? Whats your budget?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-04-2007, 05:00 PM
Thanks for the reply, and sorry about posting in the wrong area...
I looked everywhere for answers to my question and couldn't find it. :S
Lets not worry about my budget for now.
What would you reccommend for a good turbo that will give medium HP gains,
and what would have to be done to the car to make sure that the new turbo and associated parts will not cause damage to the car?
The last thing I want is to spend money REPAIRING the car after ive already spent money improving the car :S
Old 04-04-2007, 05:10 PM
steviek's Avatar
steviek steviek is offline
|My bet is you need a 16g. Get the evo 3 one if your going to get this turbo.
|Benefits; very fast spool. Cheap. Reliable. Maintains stock exhaust manifold/02 housing |(if you so choose). | won't rip up your trans and stock internals will hold
Makes up to 380whp on a gsx. Very nice mod.
Requires|: fuel mods |(fuel pump new injectors|) safc or some other form of engine management, a boost gauge |(obviously) and some form of logger or wideband o2, can use stock sidemount recommended almost a necessity front mount.
Cons: won't be beating any z06's best for autocrossing not really dragstrip (but still good|)
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 04-04-2007, 05:17 PM
Thank for the reply man, I agree with you too.
I have been doing a lot of research (better safe then sorry) and I also believe the evo 3 16g looks to be the best for reliability and from what I've read/heard it isn't too much too handle.
Well, like I said I just got the eclipse and some old guy owned it.. (bahaha) so its been pampered pretty well, its all stock and has had nothing done to it... Got any idea what kind of exhaust I should get for it? I have been looking around and from what I have seen exhausts are either really cheap, or REALLY expensive... and because of that its hard for me to tell which one would be good for what i want which is just a nice exhaust system that isn't over the top
Also, have had some trouble with fuel pumps in the past (my T/A) and I didnt want to have to cut my car all apart to replace it because it had been welded together previously so I asked around to see how much it would cost to have it professionally done... the estimate was like 600 dollars... thats not including parts. LOL ... any suggestions there? and pointers to a good fuel pump?
Sorry for the questions but, I figure I ought to learn from the ones who know and not the ones who dont
Old 04-04-2007, 05:31 PM
steviek's Avatar
definitely not 600 dollars to get a fuel pump done
|It took me 30 mins to switch mine you get it from under the back seat no prob. I have a walbro 190 its great no need for a fpr. walbro 255 needs one. They are like 90 bucks and the install you should definitely do yourself there is a write up on vfaq.com
As for the exhaust... well all an exhaust really is a metal tube that spits out gas. So its not like one company really makes a better one than the other. Mandrel bent piping is the best I guess as for diameter a 3 in turboback is the way to go. hi flow cat and stainless steel flex section. As long as it fits the car and the hangers are in the right spot your good to go.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-04-2007, 06:00 PM
Lol sorry I am kind of unknowledgable, what is a SAFC or a wideband o2? :S i feel so newbie
Old 04-04-2007, 06:41 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
SAFC = Super Air/Fuel Controller. This while allow you to make adjustments to how rich/lean your car will run.
Wideband o2 sensor is a more accurate oxygen sensor. It has a wider range than the stock o2 sensor and will let you know your air/fuel ratio.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-04-2007, 06:47 PM
Ahhh i knew that... Now i feel stupid the front or side mount is what confused me :P
If I get that turbo and do a couple other minor upgrades to the car, what do you personally think would be a good boost pressure level to adjust it to?
Old 04-04-2007, 07:40 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
You really need to check out www.VFAQ.com and 1000 allready answerd questions..
DSM geek
Old 04-04-2007, 11:18 PM
Thor06's Avatar
Jizzed In My Pants
For a "medium" setup, heres what I would do (actually, this is what I plan on doing eventually):
-Evo III 16g
-190
-650 or bigger injectors (limited to 650's if you go with SAFC/pocketlogger combo)
-Either SAFC/pocket logger or DSMlink (DSMlink FTW)
-Boost and oil pressure guages
-Boost control (manual boost controllers are fine)
-3" turbo back exhaust (brand doesnt mean shit)
-K&N filter
-FMIC and hard piping (eBay shit seems to be fine but for a smaller turbo like this dont go TOO big)
-BOV (1g if <20psi, HKS SSQV or Greddy RS if >20psi)
Other stuff that would be nice:
-Better clutch (ACT 2100, Fidanza 2.1, Exedy Stage II are all decent clutches IMO)
-Cams (I would personally go with Forced Performance 2 cams but FP1, HKS 264, or HKS 272 cams would all be good)
-1g head swap (In my opinion, a 6 bolt swap for a 16g is rediculous overkill, however that 2g head is worthless IMO. I would swap it for a 1g head, keep the 2g exhaust mani and get a 1g intake mani)
-Shift stuff such as short throw, bushings/bearings, etc
-Suspension
-Tires
-Good brakes
Yeah, thats pretty much what I would do if I were you, but not in that particular order. Check the upgrade path on dsmtuners if you are unsure what to do first.
Old 04-05-2007, 12:35 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
380!?!?! are you sure!? that seems kinda high...
Old 04-05-2007, 01:03 AM
Thor06's Avatar
Jizzed In My Pants
SBR made 422hp/462tq on an AWD. Linky
Old 04-05-2007, 07:34 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I highly suggest you take care of the supporting mods first, such as a BOV, injectors, fuel pump, fuel controller, exhaust, downpipe, cat / test pipe, intake, plugs, wires, timing belt, etc. Then worry about a new turbo.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-05-2007, 11:20 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
I agree, save the turbo for last. Also, you might want to look into a 50 trim; its a close contender, if not better, than an EvoIII16g.
The daily driver. The weekend cruiser. The lazy shop hog.
