Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 04-04-2007, 10:14 AM
LMP's Avatar
LMP LMP is offline
From CAJUNHOPPER : problem with heater
archived thread on that subject: http://www.automotiveforums.com/vbul...eply&p=4693449
Originally Posted by cajunchopper
Regarding this problem, is there any website that would have information, to include photo's, to change these items? I am having the same problem with my '99 Sportage. Blower does not work, but with engine on and fan speed switch on high, there is a slight change in engine speed. Whatever can be provided would be great.
WOuld be interesting to get some more details. I understand the "heater blower" does not work but the car "engine speed" changes....
ANyway here is the electrical diagram:
www.geocities.com/lmp4203/kiasport/kiablower.gif
You can register at
www.kiatechinfo.com
to access all kia manuals. However the instructions to access blower motor are out of proportions. Several kiaowners have removed the motor unit just by crawling under the dash and taking s few bolts and nuts away and reported that is a good idea to remove some leaves and other debris from the inside of that area. I've not done it myself..yet.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-04-2007, 09:54 PM
cajunchopper cajunchopper is offline
Re: From CAJUNHOPPER : problem with heater
Thanks for information. To provide additional info, blower worked only on high, then quit completely. I noticed during troubleshotting that when engine was running, and turned fan switch to high, there was a noticable change in engine speed, like there was a current draw somewhere causing the engine to slow down a bit.
Old 04-05-2007, 05:52 AM
LMP's Avatar
LMP LMP is offline
I think you have a description of same problem here, and the way to go.
HERE
Old 04-07-2007, 10:04 PM
hvac1000 hvac1000 is offline
HERE
Could be motor OR the blower motor resistor that controls speeds of the motor. That is located right next to the blower motor itself.
Old 06-23-2007, 12:10 PM
Changed both and works fine!!
