Go Back   Automotive Forums Car Chat > Ford > Freestar
Old 04-03-2007, 09:03 PM
brinkz brinkz is offline
Cruise control
Just bought a 04 freestar sport...the cruise was fine when i test drove it, now all of a sudden it's not working anymore. Turn it on and press "set" and the green "speedo" light flashes on then off, and no cruise. Any ideas before i take it to the dealer. Unfortuantly i dont have a manual for this vehicle, but I am guessing the BOO switch or pressure maybe?
Old 04-04-2007, 03:14 AM
KimMG KimMG is offline
AF - Advisor
Re: Cruise control
Check to see if the brake lights are working.
Old 04-04-2007, 11:05 AM
Re: Cruise control
Ahh good call, never even thought of that....strange enough though i went out for another road test with it, and it's working again. Cant duplicate the problem.
Thanks. i will check next time it craps out to see if the brake lights are working or not.
Old 04-07-2007, 07:23 PM
Re: Cruise control
ok just to recap, when the cruise isnt working i get the green light flash on the dash, just once per "set" attempt. I read on another forum that a few people had this exact same problem, and it turned out to be the cruise control disconnect switch. You know the 20$ one that FOrd has a massive recall on right now. Anyway I think I will try that to see if that works.
Old 04-17-2011, 03:32 PM
dyankee1995 dyankee1995 is offline
Re: Cruise control
Same thing happening here...just bought a 2004 Freestar and although the cruise was working when we test drove it, it no longer works...
I tried looking up disconnect switch on an autoparts website but it was listed for over $400. Where are you getting a $20 part?
Old 05-12-2011, 12:15 PM
s1120 s1120 is offline
Re: Cruise control
You need the cruse brake switch located on the mastercyl. The number of the one for my 06 is 7F2Z-9F924-a and lists at $33.71
I put one in mine a few years ago with the same problem you have, and it fixed it. Mine just stopped working agean, but I get NO lights this time. I was hoping it was the switch agean, but it was not
