head gasket
just was told had leak starting in head gasket and i'm wondering how difficult it is to repair and where i would find out info to repair. garage man said it would cost from $400-600 there. would like to attempt to do myself.
Re: head gasket
This on a scale of 1-10, 10 being the most difficult ,is about a 7-8 for an amateur. Tough to comment here without knowing your skill level and access to tools necessary to do this job.
Re: head gasket
Quick calculation in doing it alone Car Manual- 10-20 head gasket set 80-100 head bolts 15-25 torque stick 20-30 total 125-175 but not including fluids you should do while you're at it also a shop vac would help to vacuum out the cylinders in the block. so really if you wanted to just save the hassle have a mechanic do it although it is good to learn how to d-i-y. (I have done about 7 engines/almost complete engine jobs in the past 6 months )
99 olds alero 2.4 DD 92 notchback with 460 carb'ed |
Re: head gasket
Is it leaking oil or coolant? If it's leaking coolant, I would get a second opinion. It is extremely rare for head gaskets to leak coolant on the 4.3L V6. More likely to be the lower intake manifold gasket. An unscrupulous shop could recommend replacing the head gaskets, when all that is really necessary is the lower intake gaskets. Very substantial difference in cost.
Re: head gasket
1. I agree with "old master" and had to replace my intake manifold gasket two years ago because of a coolant leek.
2. If you know the shop is really good and won't cut corners I say take it in. If this isn't the case you may want to do it yourself, if you are comfortable with this job. If doing it yourself and you want to keep this truck for a long time there are a lot of things you can replace depending on the truck's condition. If you have a sticky lifter at startup it may good to replace the hydraulic valve lifters. With the heads off you may notice the valves are not looking too good so it may be time to get the heads machined and replace the valves. How long do you want to keep this truck? |
