Old 04-03-2007, 12:01 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Question of design....
I meant to ask a while ago, I was doing a lower intake gasket on a 350 not too long ago and noticed that the rear two cylinders' coolant passages are blocked off. Why is that?
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 04-04-2007, 12:26 AM
Morley Morley is offline
Re: Question of design....
Not needed on the iron headed engines. The aftermarket intakes have those passages open for more even cooling with aluminum heads.
Old 04-12-2007, 11:09 AM
macker914 macker914 is offline
all of them are like that.....both iron and alum.....if you get the right intake, you can put heater hoses to those ports.....and then just cut out the gaskets, if they don't have those holes...
Check my sig.....everything is cast iron (block and heads)...and i have an alum intake that has bosses to screw in hose adapters to run the heater hoses out....u do not have to use alum heads to get that...I am not!
EZ Online Mechanic
Ryan
'91 Chevrolet Camaro wit da Kenwood Hot
433 Stroker SBC (go-getta)
