too much oil
What are the negative effects of overfulling your engine oil by 2 quarts?
Specs: 1999 Camry Milage 122000 Vehicle is in mint condition inc. engine and tranny |
Re: too much oil
does a 99 ce have abs?
Re: too much oil
Too much oil can cause cavitation (air bubbles) in the oil. This will cause excessive wear. It's nearly as bad as not having enough oil. If you've run it more than a couple hundred miles like this, you may have decreased the life of the engine. If it was less than that, I wouldn't worry about it.
According to MSN Autos, ABS brakes were optional on your car. If you see an ABS warning light on the dash at startup, you have ABS brakes.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
Re: too much oil
Pull the drain plug long enough to get the extra oil out. Check the level on the dipstick and keep the level where it should be. You may have no problem if you do it soon.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
Re: too much oil
As RIP and Brian have noted, overfilling is bad juju. You can wind up blowing seals. Up on the ramps, crack the plug, drain as needed. Ramps will cost you $30. Engine repair will cost you $1000. The math seems simple.
