Old 04-03-2007, 06:54 AM
PlayStation3 PlayStation3 is offline
wiring question
ok, i just bought a kicker 05pk simething wiring kit ( the duel amp 0 guage kit) and i was wondering if i could run the 0 guage as my main power wire split it into 2 4 guage then split one of the 4 guage wire into 8 guage wire for my speaker amps. which will be pushing around 225 watts total per amp. but the sub is going to be around 1500 rms
Old 04-03-2007, 12:51 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: wiring question
should be okay.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 04-03-2007, 02:17 PM
Re: wiring question
even with my edit about the subs?
Old 04-03-2007, 04:57 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: wiring question
0 gauge should be able to handle around 3k watts with no problem. Ive seen some companies rate it at between 3k-5500. And you wont always draw that much power so it will be fine.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 04-03-2007, 05:08 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: wiring question
wires are rated for amps not watts. I usually use the rule of thumb that the next bigger wire can supply 2 of the wires you are using. In your case, a 1/0 gauge wire can feed 2 2 Ga wires, which in turn each can feed 2 4 Ga wires of their own.
Old 04-03-2007, 06:18 PM
Re: wiring question
so it is fine. plus i heard that kicker's hyperflex wire is almost the next guage bigger
