Old 04-03-2007, 12:09 AM
X2Xtreme360 X2Xtreme360 is offline
condensing headlights
I found a photo on google a while ago which unfortunately I can't seem to find now, but it was a 3000GT without the glass covers on the headlights. I'm pretty sure they weren't custom or anything, just the headlights without the glass over them. It looked kinda cool, but I don't know if it would be a good idea. I have condensed headlights and was thinking rather than cleaning and replacing the covers, I could just leave them off. I DO have glass covers and not lexan on my 94, just so no one asks, but would this not be a good idea for any reason?
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 04-03-2007, 04:28 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: condensing headlights
Rocks could bounce up and break a bulb?
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 04-03-2007, 06:37 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
They look 100 times better with the glass. You can tell somethings missing without them. Cleaning is not that hard.
Old 04-03-2007, 07:53 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
94 is the only year they were glass, so assuming you still have the stock headlights yes you have glass ones.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-03-2007, 08:16 AM
DSM Monster DSM Monster is offline
yeah i just saw that gt last night too.
Old 04-03-2007, 08:48 AM
Those are the 95+ lights with the covers removed and the inside painted black. Your lights will not look like that if you remove the glass.
Old 04-04-2007, 01:56 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
what you could do (i've had friends that have done this) is remove the glass cover and remove the paint from the inside (bottom) of the cover. then you replace the cover, and you will be able to see the insides of your headlights, but you'll still have the glass cover protecting them from road debris.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-04-2007, 02:25 PM
Scrapper Scrapper is offline
AF Premium User
Smile Re: condensing headlights
most cars now days do the moister thing..my sister had a dotsun do that i took them out took lite buls out and to the purple cleaner in them and let them air dry before putting them back in and problem gone you might even take rainex..good luck...
