Old 04-02-2007, 10:34 PM
georgie95020 georgie95020 is offline
Question i replaced the water pump,but now the bely or pully squeaks
the water pump on my 97 chevy blazer has just went out, so i got the instruction from this site on how to replace it. keep in mind that the truck was sitting for about 3 years and from the time i started drivivg it until the time that the water pump went out the noter sounded great and run really good. so i went down to autozone and bought the parts and that special tool to take off the cluch plate, and i replaced the water pump but now when i start the truck it makes a squeakimg sound like the belt was slipping but now im thinking that maby when the water pump went out the first time and the rusty water shoot out all over the place it might of made one of the pullys a little squeaky... can someone help me please
Old 04-03-2007, 12:05 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: i replaced the water pump,but now the bely or pully squeaks
Make sure you got the belt on right, with all the little grooves lined up. Next, take the belt off, bend it backwards and see if it has any stress cracks on the inside of the belt that run across the grooves, if so replace it. Also, with the belt off, check the pulleys to see if they feel rough when turning them by hand (bad bearing) or if they are loose or wobble.
Old 04-03-2007, 12:21 AM
thank you ill make sure to tay that with the belt but about the pullies i remember that the pully with the spring on it. i think its called the tension pully, its hold the belt on tight but it looks and feels a little lose but the bolt on it is tight. what do u think about that.
Old 04-03-2007, 12:49 AM
DelCoch's Avatar
If in doubt I would replace the tension pulley, maybe the whole tension unit. They are not high dollar. But, check the other things also. You could have more than one problem. Also, try to turn the alternator fan and pulley with the engine off. If the pulley slips on the belt it is too loose (bad or broken spring in tension pulley) or the belt is glazed and must be replaced.
Old 04-03-2007, 05:56 AM
muddog321 muddog321 is offline
AF -Advisor
Also check the idler pulley and that alternator - been sitting so....
Old 04-04-2007, 04:15 PM
someguy000001 someguy000001 is offline
On my '97 I had to replace the tensioner arm a few years ago and I just replaced the tensioner pulley a few months ago. My OEM tensioner fell apart one day, and the replacement is a different design.
Also, if it sat for 3 years it's time to replace the belt. Check the pulleys while it's off.
