Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-02-2007, 10:47 PM
tsi4444 tsi4444 is offline
Wideband
I recently got around to purchasing my fuel system and Dsmlink. I have been reading up on tuning to try and figure out what I am getting myself into. I have noticed that a lot of guys have paired up a wideband O2 with their Dsmlink. I was just wondering if you guys think this is necessary and if so what is the advantage of having a wideband along with the Dsmlink.
97 TSI AWD
Apexi N1
RRE Downpipe w/test pipe, K&N FIPK, RRE lightened flywheel, ACT 2600, New short block installed due to crankwalk,autometer sport comp boost gauge,type-s bov, brode uicp, Johnny race car fmic with custom piping, evo 3 16g
Soon to be purchased: DSM link, injectors, fuel pump
Old 04-02-2007, 10:50 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Wideband
Yes. Widebands help a lot with no matter what tool you're using to tune with, whether it be DSMLink, APEXi ECU mappers, or even a AFC. Helps way much and is higher recommended.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-03-2007, 12:16 AM
steviek's Avatar
steviek steviek is offline
Re: Wideband
yea and plus there is an awesome writeup on how to install it
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 04-05-2007, 11:21 PM
TheRomer TheRomer is offline
Re: Wideband
OK, I'll actually answer your question for you. Wideband 02 kits are used to read exactly what it is called, Wideband. Your stock 02 sensor is only a narrowband sensor. So to put it into perspective, the 02 sensor is by no means as accurate as a wideband sensor. It is a lot more easy to tune with, becasue the Air/Fuel ratio you are getting with the widebands are usually within .1 AFR, which means it is extremely accurate. They take about 100,000 samples a second, so the info you get from these sensors are so much greater then your stock 02 sensor. Whats does this mean?
You can tune more accuatley, and also not have to worry about running too lean or too rich. They are simple to hook up, and also simple to tune with. Once you get one of these, you will never trust an 02 sensor again.
Old 04-05-2007, 11:40 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Wideband
I don't think you are getting your money's worth out of DSMlink unless you are logging WBO2 and Boost through it. These two additions increase the usefulness of DSMlink by a factor of about 10 million. IMO/YMMV.
I don't think WBO2s can actually sample at 100 times/sec. I'm almost positive most WBO2s refresh every 65 milliseconds or so, but I can't for the life of me remmeber where I got this information... At any rate, you're limited by your sample rate in the logger regardless of how fast the WB samples, and with DSMlink, the sample rate is not very high, especially for 1Gs.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-05-2007, 11:45 PM
Re: Wideband
Well Kevin, knowing you and all, I would take your info over mine any day, I actually got that info off of ExtrememePSI, since I am in the market for one as of right now. But they are probably just trying to sell the product. Damn salesmen . You are also correct on the logging program. DSMlink certinaly cannot keep up with that rate of speed .
Edit> Just checked it out again, and that 100,000 times a second is actually the linear output, not the actual sample rate. That would actually be 10 times a second according to the site. My bad.
Old 04-07-2007, 08:02 PM
Re: Wideband
Thanks for the replies, I searched around on the dsmlink forums and decided to go with the innovate lc-1 wideband. I got it for $180 off of ebay which seemed like a good deal to me. Kjewer1, you mentioned logging boost through dsmlink and I was wondering how i go about doing this. Sorry if its a stupid question, but I am very new to this tuning game.
97 TSI AWD
Apexi N1
Old 04-07-2007, 08:35 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Wideband
I used a GM 3.3bar map sensor, cliped my MDP sensor and solderd the weather pack into the MDP wires. Then just sellected the GM33bar value in the Captured Values menu of DSMlink, and sellected the MDP input option..
DSM geek
Old 04-08-2007, 08:37 PM
Re: Wideband
Could you explain what a Gm 3.3bar map sensor and what MDP sensor are.
Thanks in advance
97 TSI AWD
Apexi N1
Old 04-10-2007, 01:32 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Wideband
Haha, as well as I understood that, I think you're going to need to elaborate a little more for tsi4444. What you said to him was like trying to give me directions in Japanese, I wouldn't have understood a WORD of it.
95 Talon TSI AWD
97 Eclipse GST
