Old 04-02-2007, 08:29 PM
poullos123 poullos123 is offline
Shaking Steering Wheel when exiting freeway
Hi there, i have a 92 Cherekee Laredo, 6 cyl, automatic, 4 door, and lately i am experiencing an unusal behavior. When exiting from the freeway where in speed over 50mph and turn the steering wheel a little bit and keep it turned a bit then out of a sudden the steering wheel starts to shake really hard like you enter a bad dirt road and when you hit the breaks and you slown down it stops and then take offs like nothing happened.
Please help me track down the problem and what i need to do to fix it as this was very dangerous and can crash me the next time it happens.
Thank you
Old 04-02-2007, 08:38 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Shaking Steering Wheel when exiting freeway
Death Wobble or DW.
Search...or go to a Jeep specialist.
Old 04-03-2007, 06:56 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Yup, do a search in the Wrangler forums about it.
However, check your alignment and tire balancing first, those alone might clear up the problem.
Also, if you haven't rotated your tires for awhile that may be contributing.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-04-2007, 07:01 AM
eep1's Avatar
eep1 eep1 is offline
I replaced the steering stabilizer and the front shocks, after alignment and balanceing of the tires. It just about stopped. I figure the next step will be replacing all the bushing up front. Start small...then go big.
Old 04-04-2007, 10:18 PM
AlohaBra's Avatar
Cool Re: Shaking Steering Wheel when exiting freeway
Have you guys ever noticed if it changes when you have a full tank of gas vs. when the tanks is empty?
That changes the caster angle on the front axle.
Old 04-13-2007, 03:20 PM
bbaskar bbaskar is offline
Thank you
I was experiencing exactly same problem (I have 93 same as yours). I am not mechanically inclined at all; here is what my mechanic told me:
-Check the is hydraulic shock & tie rod to front weels..both were changed on mine ($200 repair) it and mine runs fine now.
Hope this helps.
Bob
Old 04-13-2007, 09:58 PM
AlohaBra's Avatar
TIP...track bar
Old 04-15-2007, 02:53 PM
gmsigns gmsigns is offline
Partner my nephews jeep was doin the death woble and shake and my brother told him to tighten all the bolts on the suspension and steering box to chassis and by god it worked! Cost 00000000000!
Old 04-16-2007, 09:02 PM
AlohaBra's Avatar
I just ordered a new track bar. Use an adjustable one if you have a lift.
Old 04-24-2007, 05:19 AM
Stick89's Avatar
Stick89 Stick89 is offline
Send a message via Yahoo to Stick89
Check the tread on the tire"SOMETIMES"tread can shift....or a tire can get out of round...
Make sure all wheel balancing weights are in place...
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
