Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 04-02-2007, 08:34 PM
miamibob's Avatar
miamibob miamibob is offline
Two Questions
I have a '93 GM with the following two questions:
1) Does it have a DPFE Sensor (for the EGR Valve)? The HELMS Manual does not show one and I have not seen it in the car. If so I would think it would be on the firewall or very near the EGR Valve
2) I am getting a "Anti-Lock Brake" Light that only comes on sometimes. Is there anyway of reading the codes without a code reader (like the Air Bag light where you count the flashes)? MB
Old 04-02-2007, 08:58 PM
reekor reekor is offline
Re: Two Questions
Yes it has a PFE sensor, mounted on the back of the throttle body elbow. It's attached to the same bracket as the egr vacuum regulator. My manual says.....
Note: Ford does not provide procedures to retrieve trouble codes without the Super Star II tester.
If you plan on working on this car, you might be interested in this Ebay # 280099837589. This $70 scan tool will pull abs codes along with engine codes on your car. It's also upgradable for GM, Chrysler and ODB II
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 04-02-2007, 11:13 PM
miamibob's Avatar
Re: Two Questions
I'll check on that sensor, as soon as I get a chance. As for the tester you mentioned, I checked and it does NOT test ABS codes. Too bad as it is at a good price. Many thanks....MB
Old 04-03-2007, 10:24 AM
Re: Two Questions
Bob, why would I tell you that this tool pulls abs code when it doesn't? Are you one of those hard to get along with types? LOL But I do own this tool and have pulled abs code with it from a 92 grand marquis and a 94 crown vic without problems. When you select any of these car it asks if your model has abs, when yes is selected it adds the abs menu to the list of options.
Or you can go with one of these for $2000
Old 04-03-2007, 11:25 AM
miamibob's Avatar
Re: Two Questions
Actually I am VERY easy to get along with. The reason I said it does not pull ABS codes is because that is what I was told by the guy selling them on EBAY. I would think he would have no reason to lie but if you have one and it does work I'd be VERY happy. Just didn't want to buy it and it already pulls the codes I already can with my reader (Innova 3145). Thanks for the speedy replies!! MB
Old 04-03-2007, 12:28 PM
miamibob's Avatar
Re: Two Questions
By the way - does it pull ABS codes from the same port as engine codes or do you need an adapter/cable because the port is different? MB
Old 04-03-2007, 12:31 PM
Re: Two Questions
It will do the abs code no problem on your 93, I just dont think the seller is aware of the fact,I cant see them removing the option. It's even listed in the ford cartridge manual on page 12.
Old 04-03-2007, 12:35 PM
Re: Two Questions
Nope, The connector for the engine is on the drivers side inner fender as you may already know. The the abs uses the same type of connector on the passenger side inner fender.
Old 04-03-2007, 12:53 PM
miamibob's Avatar
Re: Two Questions
Hi Reekor!
You are "on the ball" and I thank you for the speed of your replies and all the great info you have given me!! I'm going to order the reader as soon as I leave this site. Again, many thanks and I'll be back here when I get it and get some results (codes). MB
Old 04-03-2007, 03:03 PM
Re: Two Questions
Not a problem. This scantool is an old gem long forgotten. I bought it years back for about $350 used and fully loaded with all cartrages and cables, you might find it hard to beleave, but at one time it sold for a $1000. and like I said its upgradable, you can find cartrages with cables on ebay for around $30. The ford cartrage will also read mecs with an extra cable. It will also give you an ecm data stream on the engine side. You'll find this tool a heck of an upgrade from your code reader.
About a year ago I thought that it was time to upgrade and I bought a autoxray 6000 scantool for $400 on ebay and for the older fords it doesn't even do all the things this old actron does, no abs, no cylinder balance test notta. Then I bought a otc Genisys and that does it all plus some, still not as nice on ford as the ngs test, The ngs will be my next toy.
Let me know what you think of it once you get to try it out.
Hi Reekor!
