Old 04-02-2007, 10:59 AM
treavie treavie is offline
Engine light and traction coontrol light on
I have been having trouble with traction control and engine light on. I disconnected battery, connections to ECM etc, and still lights are on. Was told that a misfire could cause trouble, so off with lid and check spark plugs and all associated hardware. Is ABS sensors tied in this problem. Any info would be appreciated. Thanks.
Old 04-02-2007, 01:19 PM
pryornfld pryornfld is offline
Re: Engine light and traction coontrol light on
I just recently had the same problem. I contacted chev and asked them about the hub assembly (as mine was bad and in need of replacement). It appears that if you have a problem with your hub/bearing it can cause the sensor to mis-read and turn of the ETS and cause the ETS Off Light and Check Engine light to come on. I replaced mine this weekend, and it appears that it may have been the cause.
Check the forum and try using Electronic Traction into the search.
