Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-02-2007, 10:26 AM
jamesdbradley@exci jamesdbradley@exci is offline
94 caprice ls 4.3v8 swap with LT1 will not start
My car will not start i have fuel pressure and sparks but the car will not turn over, unless i spray starter fluid in it and then it only runs for a minute or so. I have tested everything i can think of anybody have any suggestions what should be my next step.
Old 04-02-2007, 10:39 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 94 caprice ls 4.3v8 swap with LT1 will not start
1 - "does not turn over" means does not crank. "Does not start" is your problem.
2 - Double-check ALL of your wiring - the engine PCM harness, the engine wiring harness, etc. You DID update the PCM for the new engine, didn't you?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-02-2007, 05:27 PM
Im not sure what the pcm is it the main computer if so i changed it
Old 04-02-2007, 05:44 PM
silicon212's Avatar
Confoundingly Lucid
PCM = powertrain control module - yes, this is the engine/transmission computer. You did get the right one for the engine, right? You did make sure that the system is fully connected and operational, no?
Old 04-02-2007, 05:51 PM
yes i have the one that came out of the 94 impala that the motor came out of
Old 04-03-2007, 08:48 AM
Blue Bowtie's Avatar
Registered Offender
What happens to the "Security" lamp when you turn on the ignition (without starting the engine)?
