Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-02-2007, 09:27 AM
eagleesi1953 eagleesi1953 is offline
squeeky suspension components
97 Eagle Talon ESI,my front right suspension when turning or going over a small bump squeeks like crazy. When you push on the hood up and down you can really hear the squeek. I used WD-40 on all the bushings and control arms,it got better but it is still there. Does anyone have any idea how to repair this problem. The steering and handling is fine but the squeek drives me crazy.
Old 04-02-2007, 09:41 AM
Killa's Avatar
Killa Killa is offline
Re: squeeky suspension components
the belt ?
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 04-02-2007, 09:48 AM
It is definately a suspension part . With the engine off and pushing on the fender,you hear squeaking as you push up and down.
Old 04-02-2007, 11:09 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Try greasing everything up real good, WD40 evaporates too quickly. If that dosn't work, you may need to start replacing things.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-02-2007, 04:10 PM
foozlemonster foozlemonster is offline
I am having the same problem on the driver side of my eclipse right now. I think it has something to do with the upper control arm. I hate that these cars do not have any grease fittings...or do they? I am 90% sure that it just needs some good grease. Good luck getting it in there.
Old 04-03-2007, 07:43 AM
Update: After thoroughly spraying all the rubber bushings and control arms,it seems to have gotten better. None of the suspension components are loose and the bearings are ok. I am going to use silicone grease because I know WD-40 will evaporate and the sqeek will return.
Old 04-03-2007, 05:32 PM
I found the squeak to be the lower control arm which has the ball joint. This model had a recall and they were originally replaced on a recall. Does anyone know if they wil replace the same parts again?
Old 04-03-2007, 09:24 PM
They should. I have read on here that several people have had numerous recalls done on the same car for that. Contact a few dealers in the area and see if you can get them to do it.
'92 3000gt SL
Zoom Stage 1 Clutch
