Old 04-02-2007, 08:53 AM
djshyc's Avatar
djshyc djshyc is offline
Question 96 Jetta 2.0L GL WONT STARt. Has Spark Has Fuel Pressure. Just died while idling.
Ok so I ran my Jetta throughout the day just fine with no problems. I came home left it idle for 2 minutes and came back to it running rough. My girlfriend said it had stalled out and she had restarted it. So I press the gas and it stalls. I restart it and it does this a few times. I do this a few times til it ends up just idling smooththen I put it in gear and it stalls out again. Then it becomes harder to restart. Battery is still strong. It just wont start? So I leave it overnight then in the morning it will not start at all still.. It just tries but nothing.. It doesnt attempt to pop sput Nil'. Actually when I quit trying to start I get a ver quick pop but nothing to speak of.
I checked my fuel pressure by taking off the fuel line that goes into the fuel rail. Plenty of pressure! Checked the spark by taking out the plug and lettin it spark off of a part of the engine while the girlfriend cranked the engine. Got spark! I even replace the cap and rotor just incase but still nothing
ANY IDEAS !!??
Old 04-02-2007, 09:57 AM
gouldie1903 gouldie1903 is offline
Re: 96 Jetta 2.0L GL WONT STARt. Has Spark Has Fuel Pressure. Just died while idling.
see if the fuel injectors are spraying fuel. you can either get a volt meter, the voltage should vary from the injectors being open or closed, or just take one out with a bucket near by.
67 chevy c 10 needs paint
01 mustang gt needs hp
