Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 04-02-2007, 07:26 AM
jeffgreene7 jeffgreene7 is offline
shock or cushion like spring that conects on the underside of the back I NEED HELP?
SO on the back side of the motor in the first year gen neons their is this cushinon like shock or spring of absorber what ever you want to call it and i have no idea what the real name is for it and if its hard to put a new one in, or how much they would normaly go for. if you know what this is i could def use the help with the name of what is actualy is so i can order it.
thanks,
jeff
Old 04-02-2007, 08:57 AM
denisond3 denisond3 is offline
Re: shock or cushion like spring that conects on the underside of the back I NEED HEL
On Neons with manual transmissions, there is a 'Power Hop Damper' on the transmission near one of the axle shafts. In my 97 the Neon Service Manual it looks like a tiny shock absorber. Removing it means working with dirt falling in your face. The manual says you can remove the top damper bracket -if necessary-, which usually means it is necessary - because of limited access down there. When you put it back in, tighten all bolts to 40 ft-lbs.
Old 04-02-2007, 09:05 AM
Bear Bear is offline
Yup Power op Damper or Bobble Strut (your choice of symantics) it is designed to stop wheel hop. Several after market ones out there, in fact A/FX as one with adjustable pre-load
Old 04-02-2007, 12:45 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: shock or cushion like spring that conects on the underside of the back I NEED HELP?
Why do you want to put a new one in?
2003 Dodge SRT-4
