Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 04-02-2007, 02:22 AM
georgiaboy107 georgiaboy107 is offline
another keyless entry problem.
On a 1991 Roadmaster Estate Wagon, how do you program the keyless entry? I removed the quarter panel, but I don't see anything there like you would see in a regular Roadmaster. I see a TRW box, but nothing empty to put a screwdriver in like the other posts said to do. Is a 1991 different from 92 and up?
Old 04-02-2007, 04:18 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: another keyless entry problem.
You should be able to follow the wiring off the TRW box to a connector that is "unplugged". In the end of the plug you will see the 2 pins you need to connect.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 06-16-2007, 11:55 AM
dallastx75208 dallastx75208 is offline
If you follow the wires to the back taillight area you will see two wires that are not hooked up to anything. One of them has two wires, the other only has one wire. On my 93 that is the wire you need to work with. All you have to do is ground that wire. You will hear all the doors lock. Once they have cycled through this while the wire is still hooked up press any button on your remote only once. Disconnect the ground and you are finished. If you are doing two remotes you need to do them at the same time.
That was on my 93 wagon. I hope it is the same for yours.
Old 08-05-2007, 11:08 AM
keller67 keller67 is offline
Question Re: another keyless entry problem.
Just bought a '96 wagon. Which side of the car is the connector on, and where do I need to go in? Is it a one wire on the '96, or a two wire that needs its contacts shorted to each other?
Old 08-05-2007, 06:33 PM
Onblsht's Avatar
Authorized Vendor
Driver's side on the 96 wagon
Old 08-05-2007, 07:31 PM
Thumbs up Re: another keyless entry problem.
Thanks!
Where, exactly, will I be looking for the connector? And is it the same as the sedan connector?
Somewhat familiar with the process from my '89 Reatta's.
Thanks again!
Old 08-06-2007, 08:05 AM
Onblsht's Avatar
Authorized Vendor
The connector should be identical to the sedan's - just in the specific wagon location.
Old 08-08-2007, 01:58 PM
I'm guessing I have to take the trim off on that side. It does not appear to be in the storage bin.
In front of, over, or behind the wheel? Just trying to determine what I have to yank.
Old 08-13-2007, 05:20 PM
Unhappy Re: another keyless entry problem.
Anyone?
