Old 03-30-2007, 02:20 PM
comet240 comet240 is offline
91 3.4 Lumina Splutter Still problem
hi me again lol
i replaced plug wires and plugs, i replaced pvc valve and fuel filter last year but when it idles its fine when i gas the engine when i driving say from stop it sputters doesnt just move so car shakes to the sputters till it gets to an rpm then runs fine only at that high rpm still will run rough at 80km too but what is it timming? or what can be done is computer bad?
Old 03-31-2007, 08:22 AM
Re: 91 3.4 Lumina Splutter Still problem
anyone have any ideas yet? i so frustrated pissing me off
Old 03-31-2007, 04:13 PM
so i tried plugs, plug wires, cleaning air miture sensor, had fuel filter replaced last year, i put fuel injector cleaner in and water seperator but car still sputtering when i floor it
so whats the problem?
Old 04-01-2007, 07:51 PM
so i still trying did some more fuel injector cleaner, and cleaned sensors but what is it why is my car still sputtering
Old 04-01-2007, 08:44 PM
91 3.4 Lumina Misfiring
i tried different things cleaning the throttle body sensors and stuff, so i not sure
any help
Old 04-02-2007, 07:15 PM
Re: 91 3.4 Lumina Miss Firing
i having bad week and seems worse seems like no one has an answer for this question, does anyone have any suggestions on what to do next minus burn the car LOL
Old 04-02-2007, 08:39 PM
cf1 cf1 is offline
check the temp. sensor.. it tells the cp how much fuel to send.. its sending a message for a cold engine when the engine is warm ...
Old 04-03-2007, 06:08 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
These cars with the 3.4 DOHC are known for developing a vacuum leak around the intake manifold base, especially after the engine is warmed up. Try spraying WD-40 around the base of the intake (the seam between the intake and heads) while the car is running. If the idle changes, you found your problem.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-03-2007, 08:52 AM
richtazz's Avatar
You already have another thread about this issue. Please don't start multiple threads on the same issue, as it doesn't get your question answered any faster, it just clutters up the forums.
Old 04-04-2007, 10:30 AM
well temperatue gag does go up to the past half way mark so that seems always normal
and ill try that wd-40 trick so i do that under the cover plate then i know i re cleaned the ports cuz i had oil in all my spark plug ports little bit in the 3 back but more in the 3 front but i cleaned them and stuff,
so ill try the penitrating oil trick and whats the solution for that, and i never repolaced plenium gasket ever cuz i have that lid off so many times for different repairs that i never both im pretty quick at removing it lol
Old 04-04-2007, 10:32 AM
ok i figured if i changed topic name get faster as it was a week before i got reply
but thanks i gonna try ur trick later too
Old 04-13-2007, 04:09 PM
Re: 91 3.4 Lumina Misfiring
ok i tried ur wd-40 trick didnt do anything no changes so i guess thats not the problem what next be thing to check
Old 04-16-2007, 05:18 AM
so any suggestions yet is it o2 sesnor? as other day i was driving car all day no problems it didnt sputter nothing but yetersday when it was raining it was back again so what can it be
