Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-01-2007, 08:18 PM
unique88 unique88 is offline
I have no idea what the problem is.
I have a really big problem. My 1995 GSX (that I just bought) is....idk. I was on the highway and heard a big pop. One big pop. My car died so I got it towed home. My idle is anywhere from 200-600 and I'm just dumping raw fuel out of the exhaust. Black smoke. I already changed out the spark plugs and the wires. I also tried switching out the regulator with one from my friend's gst. No change. The odd thing was when I unplugged my fuel pump it ran like it was supposed to, at a good idle until I died. I figured there was way too much fuel being dumped into the engine. There is a high flow fuel pump in it with no adjustable regulator and stock injectors. I ordered an adjustable regulator and bigger injectors. Just waiting for them to come in. Another thing is that when my lights are on and I revved it the lights would dim so I think it may be my alternator but would that make my idle suck and dump raw fuel? I don't know. Please help me out. I really really need it. THANKS
Old 04-01-2007, 09:09 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: I have no idea what the problem is.
Sounds like a head gasket IMO. Was the pop from the front, back? It doesn't seem like a "blown" fuel pump could even exsist. It either works or it doesn't.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-01-2007, 09:38 PM
It was from the front. I'm not leaking any oil or anything so I didn't think it would be the head gasket. I was thinking that the injectors are being overrun and they just aren't closing so they are just dumping fuel all the time. But that still wouldn't explain the pop. So I'm not sure.
Old 04-01-2007, 09:55 PM
david-b's Avatar
Dave is THAT guy
I really cant think of anything that would make a loud pop like that. The HG could be leaking inside, not nessecarily blown outward. Fuel could be leaking inside the engine when it shouldn't be.
When the engine is on, is there any knocking from the engine? Any check engine lights? Change your oil and see if there's any coolant in it.
75 Monte Carlo
Old 04-01-2007, 10:03 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Check the turbo and the piping. I had a same problem when a coupler came off. Car was burning fuel like crazy, idle was around 400. I would check for a boost leak and see how the turbo is doing. I believe your problem is there.
1997 Eclipse GSX
Old 04-01-2007, 10:15 PM
I've already fixed all the boost leaks and the turbo is brand new. I'll take the head off tom. and check the headgasket and I'll double check all the piping. Thanks for all the input.
Old 04-02-2007, 08:06 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Before you go yanking the head off, why not save yourself a bunch of time and do a compression test.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-02-2007, 10:19 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-02-2007, 01:56 PM
OK. I checked the compression and it's 120psi in every cylinder. I checked or leaks and there aren't any. I run good at idle but I still think my injectors are stuck open because I go all the way rich when I go above idle and rev. Any other guesses before my injectors come in?
1995 Eclipse GSX
GT Ported Manifold|3" Turbo-back Exhaust|Big 16G Turbo|Walbro 255lph Fuel Pump|FMIC|Lower IC Piping|KoyoRad Radiator|K+N Air Filter|Super Sequential BOV|Greddy Boost Gauge|Greddy EGT Gauge|Autometer Air/Fuel Gauge|Greddy Profec Type-S|Tien Lowering Springs|Toxico Struts|18" 5Zigen Rims|Recirc. Kit for SSQ BOV|550cc Injectors
Old 04-02-2007, 02:52 PM
Well, 133psi is the service limit, with 178psi being "perfect". Couple questions about your test....
Did you make sure the engine was up to operating temperature before the test? Did the battery have a full charge? Did you have the gas pedal floored during cranking? A cold engine and half dead battery can lead to low compression numbers.
I would also pour a little oil in each cylinder and rerun the test. This will give us more information about the cause of the low compression.
1997 Spyder GS-T
5-Speed
Old 04-02-2007, 03:17 PM
My foot was not to the floor and no the engine was not up to operating temperature. I can't do the compression test until tom. because my friend just went home with it. But all were 120psi so if I was warmed up then it would be higher right?
1995 Eclipse GSX
Old 04-03-2007, 06:59 AM
You need to do the compression test after the car is fully warmed up. The battery also needs to be fully charged and you should have the car at WOT.
Here, read this:
http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
1997 Spyder GS-T
5-Speed
Old 04-03-2007, 05:38 PM
Ok I replaced the injectors with some 450cc's from a gs-t my friend is working on just to see what would happen. Nothing changed. I don't mean to sound retarded but can someone send me or show me which spark plug wires go where? I think I may have them good but I want to make sure. THANKS
1995 Eclipse GSX
Old 04-03-2007, 06:09 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Hmmmm.... shitty idle, super rich, and a big pop from the front of the car. Are you SURE you checked all pipes?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-03-2007, 06:38 PM
Ya I'm sure but I was thinking about tearing all the piping off and looking at every damn spot on that piping to make sure....again.
1995 Eclipse GSX
