Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-01-2007, 04:13 PM
recycle_me's Avatar
recycle_me recycle_me is offline
Send a message via ICQ to recycle_me Send a message via AIM to recycle_me Send a message via MSN to recycle_me Send a message via Yahoo to recycle_me
ok got the no start thing......
Ok i have a 95 Eclipse GS-t Automatic. It has 112,000 miles on an all orignal (stock) motor. I have researched and i know my possiable problems include Crank Angle Sensor, Computer, Coil, Coil transistor. Although i dont think its my coil or coil transistor due to when i oulled it off the do the coil test with multimeter, i decided to turn the engine over with the fuel rail and injectors out of the car and the injectors on the valve cover. while i turned it over the injectors did not purge(meaning not fuel spraed out) how ever when i disconect the return line i get fuel coming out. So with all that said i belive my problem is either the computer or the crank angle sensor. Will a bad crank angle sensor cause my injectors not to purge? I know it will cause my no spark issue but im not sure about the injectors. So im asking you ppls opinons before i buy wich ever it is i need to buy. i got this guy in Florida that will give me and ECM for like 200 bucks and should have it next day. And napa has my crank sensor on shelf ready for me to get if i need. Thanx in advanced for help.
For You Are Crunchy And Taste Good With Ketchup!
Old 04-02-2007, 07:57 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: ok got the no start thing......
Don't you have another thread about this same problem? Please limit your threads to 1 per problem. There is no need to start multiple threads about the same problem.
Can someone lock this thread?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
